BBS Wheel sizing
Will BBS RS wheels off an 1988 944 turbo fit an 1989 911 Carrera?
The numbers from inside the rims are as follows:
7J x 16HZ ET 49 RS 157
8J x 16H2 ET 49 RS 158
I would like to use these without the need of spacers.
TJC
89Cab
Old 12-05-2002, 03:17 PM
avi8torny's Avatar
Send a message via AIM to avi8torny
offsets
If it's an 89 and not a C2 the offsets or ET are:
Fronts 23
Rear 10.6
You will need spacers to take up the difference on those wheels. If you are going to use a spacer, the smaller the better...they can put stress on the wheel bearings if they are to large.
The front offset requires a 26mm spacer the rear a 38mm spacer. To much IMHO.
12' GT3
18’ 991S
Old 12-05-2002, 05:14 PM
