Crank Sensors - Gradual Decline?
Hello:
I have removed the aftermarket alarm from my 1984 Targa. I have also performed the requisite tests on my factory alarm.
Still no start.
I think I have it narrowed down to either the ECU or the reference sensors. Since my starting issues were intermittent prior to the final shutdown, I am at a loss. I tested my sensors per the Bentley manual and they were within spec. But Gerry(fellow Pelican) and my tech are both telling me that the Multi-Meter test is not conclusive.
So my question is - Will a crank sensor cut out intermittently prior to complete failure?
Thanks for reading.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 12-29-2015, 07:25 AM
Measuring ohms is not conclusive. You need to use an oscilloscope to see its waveform. Change it, it is relatively cheap.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 12-29-2015, 07:29 AM
My Tech, Gerry from this board, and now you, are all pointing to the sensors, rather than the ECU. Maybe I should just change them, as they are now over thirty years old.
Old 12-29-2015, 07:31 AM
Worked for me.
Old 12-29-2015, 07:43 AM
Did your's just all of a sudden cut out? Or did you have a few times where you had a hard time starting your car?
Originally Posted by Porsche 2 View Post
Worked for me.
Old 12-29-2015, 07:44 AM
I've found several bad ignition coils recently on carreras. Everything checks out and there's some orange spark but no start. New coil, blue spark, starts right up. I keep them in stock now just like DME relays.
206 637 4071
Old 12-29-2015, 08:05 AM
patz's Avatar
What do the coils for a 964 run?
Old 12-29-2015, 08:27 AM
gtc gtc is offline
abides.
gtc's Avatar
Have you tried putting your ECU in someone else's car? It's a pretty easy check compared to replacing the reference senders (especially with the engine in)
Graham
1984 Carrera Targa
Old 12-29-2015, 08:38 AM
Wholesale from my supplier about $65.
206 637 4071
Old 12-29-2015, 08:50 AM
Actually, my tech offered me a spare ECU. He said the chances of my car damaging his unit are very slim. It does look like a PITA to change out the sensors with the engine in-situ.
Old 12-29-2015, 09:04 AM
Note well that the current Bosch coils for the 964 (silver in color) are made in Brazil and have a very spotty record. Many 964 owners are changing to the 993 coil pack. Seek here and the other forum for good details; the largest gotcha is you need new coil-to-distributor wires as the length (and I think the connectors?) are different.
'90C4
Old 12-29-2015, 09:05 AM
John, I had bought a generic 12V coil from our local Napster. It did not work. Do I need a special coil for my car?
Old 12-29-2015, 09:06 AM
patz's Avatar
Not so hard to change sensors. Also better to swap in a known good ECU into your car than a possible bad one into a running car.
ischmitz's Avatar
Send a message via Skype™ to ischmitz
To answer the OP: yes, entirely possible. Sensors can become gradually worse over time. Heat and vibration kill them. Ohm them out and for the speed sensor measure the AC voltage ~2.5V it generates while cranking. For the reference sensor measure the pulse with an LED test light or an o-scope.
And further, a bad ignition coil is possible but an entirely different failure mechanism. If the speed sensor or the reference sensor are not working there will be ZERO spark signals an d ZERO fuel signals. The DME will not go into RUN mode.
A bad coil, missing coil or intermittent coil will prevent proper spark but not impact fuel signals. So the diagnostics should first confirm whether the DME recognizes flywheel motion (NOID light on fuel injector plug). Then check if you get a proper spark. Following a lot of these posts here is a rough breakdown as I see it.
- no fuel, no spark: 45% it's one or both of the sensors, 45% no power (alarm, DME relay), 10% it's the DME itself
- no fuel, spark: likely the DME, can also be shorted or stuck injectors
- no spark, fuel: usually the DME but I can see a bad coil or ignition components downstream
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Diss Member
Quicksilver's Avatar
For the cost of one cheap BMW substitute flywheel sensor you can find a used oscilloscope on Craigslist.
- Replace, replace, replace = BAD
- Test, test, test = GOOD
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 12-29-2015, 09:17 AM
Laneco's Avatar
Yes, the sensors can fail intermittently before flat out quitting.
We had an 85 with the original sensors. I would be zipping along and the engine would just shut off (tach dropping down to nothing) and then catch and keep running. A couple of "slow" starts occurred intermittently then one day BAM. Nothing - no joy.
I checked the pins (I think I followed a testing protocol from Ischmitz) at the DME and confirmed a bad sensor. As they are a PITA with the engine in, we replaced both. By "we" I mean that I diagnosed the problem and my long suffering husband did the hard part - LOL!
angela
Hello
Old 12-29-2015, 09:24 AM
Ingo, not that I am trying to avoid sending my box out to you, LOL.
Is it hard to set the clearance for the sensors if the engine is in the car?
ischmitz's Avatar
Hi Chris,
not really - one trick is to super-glue a penny to the sensor, then shove it against the FW. That's the correct spacing. Then remove the penny.
I've seen many replace these sensors and it should be entirely doable.
Cheers,
Ingo
Old 12-29-2015, 09:40 AM
Partial engine drop helps.
Old 12-29-2015, 09:41 AM
Check that all the plug connections off of the ignition switch into the firewall are fully seated. I replaced a turn signal switch and didn't get one of these seated properly (I had removed them for access). After driving over bumps for a couple of days one of them started to work itself loose. Car started cutting out on the highway but would start back up - first sign was the speedo or tach going dead before the engine cut out. Finally would not restart. Took about half an hour to figure it out. Probably not your issue but similar symptoms. Worth a quick look before buying parts.
Old 12-29-2015, 12:37 PM
