Can anyone ID this engine?
Found this engine at local shop. I'm thinking its a 2.4 liter from '71-'73 time frame according to internet research. Can any of you experts tell me more about it? Not great pics, but best I could do. The box on top in the second pic is the intake, etc. If its something desirable, I'll go back for a better look. Sorry about the sideways pics, can't get them to rotate.
What say you? ![]()
Mark Howard Baton Rouge, Louisiana 2023 Taycan GTS |
Occasional User
My 1972 911E with MFI had a green shroud. I am pretty sure S was red, T was grey. If you have the engine number this is easy to decode. PS - short of a 72S motor, this might be a pretty special motor. For 1972 Porsche built 8200 T engines, 2000 E engines and 2700 S engines - of course the S is the ultimate to own. T/E/S hp 130/165/190 torque 196/206/216 pretty motivating / impressive for a 1050 kg car. Please post up your serial number, just right of fan.
Vince 2015 Boxster S, Black & Black 1989 Carrera Silver Coupe, Silk Grey - sold 2009 Cayman S White, Full Cocoa - sold 1972 911E Silver Coupe, Pepita & Black - sold Last edited by Cook&Dunning; 12-31-2015 at 01:19 PM.. |
7.0:1 > 11.3:1 > 7.0:1
Fixed
Looks to have hydraulic tensioner upgrade, a good sign. I can't say much more with any certainty. ![]()
That looks a lot like my motor, a 1976 CA 5R. Mine has the same green shroud. Check the case number on the right side of the fane, at the back of the base. If it starts with '656' it's from 1976.
gearhead
![]() Right of center in this picture, below the fan and above the crank pulled you will find type number and serial numbe stamped into the case. I'm going to guess that this is a 2.7. But get those numbers and what it is becomes very easy to determine.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Ok, thanks. Narrows it down a bit. Any idea on value in its current condition? Been sitting for 4-5 years, motor turned over by hand when taken out of car. Looks to need a good once over. Who knows if parts are all there. eBay is not really a good source for pricing, I have observed. Wild swings in perceived values.
Porsche's Love-em Live-em
green shroud and CIS = 2.7
Note exhaust:double inlet muffler = 1974 911 2.7 unless things been changed. Value? just parts or rebuild-able core? I would value $500-$1,500. note: hyd. chain tension-er update kit, a +. |
Based on the engine shroud and intake runners, i'd say it's a mid-year 2.7 CIS engine. not terribly rare or desirable.....but one of my favorite engines to hot rod. As it has been sitting partially dis-assembled, with the intake ports open I'd consider it a rebuild-able core. I'd value it at $1500-$2500 depending on condition/leak-down test results. Let me know if it comes up for sale.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Senior Advisor
yup lets part out the CIS and cams/pistons, send the heads out for double plugs, Jenvey ITB's, rarely8 headers, m&k 2in/out, good cams, 10:1 pistons, COP's bunch of Clewett stuff That would work fine!
08 Cayenne Turbo |
James........that works for me.
regards, al
Browsing through, I'm going for 74 2.7S
Bruce |
Senior Advisor
whats the tag say on the fan housing?
08 Cayenne Turbo |
