81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
7.0:1 > 11.3:1 > 7.0:1
I had a look at that thread and unfortunately that is a different model of transaxle than what is in your car. Your transaxle designated "930" changed to "G50" model in 1989 for the turbo cars, and for the 911 a sensor like yours was used in the transaxle designated "915" up to 1987 when it changed to "G50".
Banned
Well, that finally clarifies things in my mind. However, bad news as far as a quick fix in my case. My only hope would be to try a different sensor or cable as suggested. My remaining question is whether there are truly four and eight magnet disks and do I need to worry about getting the correct version of the sensor if I have the four magnet disk.
Banned
If you go back to that post and look at the parts manual link I provided, you will see that there is only 1 part number option for the magnet carrier (the other two part numbers are for the G50 transmission), and only one part number for the 930 sensor, as well. I also checked the parts manuals for model years 1977-1985 (the link I posted is for 1986-1989) = exact same part number for the magnet carrier and sensor for all years 1977-1988 930 gearbox. |
Thanks, I guess the four readings per revolution my test showed is probably due to the sensor or cable, as one of the other thread suggests.
That picture of your sensor shows that someone has tried to seal up the cover?
I think you need to try a new sensor. |
The reason you are only getting four pulses with one rotation of the wheel is because of the differential unit!
With one wheel stationary, you have to rotate the other wheel two full rotations for the equivalent of both wheels rotating one complete revolution. Here are three links to ponder... Sewer backs up, and speedo smokes. Carrera VDO Speedo SUCKS. VDO Really really really sucks. 930 Turbo Speedometer
Paul 2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS. Last edited by ewave; 01-11-2016 at 10:49 AM.. |
No, that was my doing the first time I tried to remove the sensor. I stuck a screw driver in the slot between the outer ring and inner protrusion, and tried to pry it out, breaking off a piece of the plastic molding that insulates the wire connections (stupid move). I don't think I did any harm and glued some epoxy over it. It behaved the same before and after.
Once again. There is nothing wrong with your sensor and the number of pulses you counted. The problem is in the speedo. it's probably a failing capacitor.
I can't believe I am on the only one in this thread who understands what happens when you keep one wheel stationary when you have a differential unit involved.
Paul 2001 CLK55 AMG, 1987 911 Turbo Look, 1997 Viper GTS. |
Ok, focusing more on the speedometer itself, I took it apart to see if I could maybe just try replacing the capacitor and see what happens. It looks like more of a delicate operation than I could handle. I assume the capacitor is the gold cylinder, with 47/16 written on it. The soldering of the pins into the board without damaging the circuitry on the back makes me hesitant to do it myself. Which brings me to ask if anyone knows anyone near Houston who can test/rebuild these speedos.
Well, today I took the speedo to a specialty shop to get it tested and they said it is working fine. So back to square one. I guess I have to take the plunge and buy a new sensor to eliminate that as well.
Just because the speedo works on a test bench doesn't prove it will work correctly in your car. Did they vary the Power Supply Voltage up to 16 Volts when testing it?
