Question What would you do?
Your driving along hit a bump and the engine starts stumbles. It doesn't clear until you push in the clutch and rev the engine. This only happens after hitting a bump.What would you check? The car has webers.
Bruce
Old 12-04-2002, 11:22 AM
Super Moderator
cstreit's Avatar
Umm... sticking float triggered by the bump?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-04-2002, 11:31 AM
don't hit bumps?
Old 12-04-2002, 11:33 AM
Early_S_Man's Avatar
Porsche Crest
Long time no see ... good to see you're posting, Bruce!
If there is a second or more time delay between hitting the bump and the engine stumbling ... it may be something like trash in the float bowl moving and blocking one of the jets.
If the stumbling is virtually instantaneous with the bump, then I would bet something like a loose or corroded connection in the ignition system is causing the stumble!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-04-2002, 01:41 PM
i had a bad key switch that would engage the starter every time you hit a bump. put a volt meter on the ign and find some potholes.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 12-04-2002, 02:07 PM
