Your driving along hit a bump and the engine starts stumbles. It doesn't clear until you push in the clutch and rev the engine. This only happens after hitting a bump.What would you check? The car has webers.
Bruce |
Super Moderator
Umm... sticking float triggered by the bump?
don't hit bumps?
Long time no see ... good to see you're posting, Bruce!
If there is a second or more time delay between hitting the bump and the engine stumbling ... it may be something like trash in the float bowl moving and blocking one of the jets. If the stumbling is virtually instantaneous with the bump, then I would bet something like a loose or corroded connection in the ignition system is causing the stumble!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
i had a bad key switch that would engage the starter every time you hit a bump. put a volt meter on the ign and find some potholes.
72 911t grey/black mine 74 914 2.0 black/ tan hers 02 g500 black/black womanproof 01 f250 psd dirty the mule 60 correct craft starflite cool 69 correct craft torino hauls butt 72 correct craft ski nautique fun 66 vw 1500s will finish someday Last edited by tryan; 12-04-2002 at 03:26 PM.. |
