kmoush's Avatar
Milky Gearbox Fluid - What does it mean?
I recently purchased my '86 911 Coupe (my first 911). As part of the initial PM efforts, I replaced the gearbox oil and when I drained it noticed the color was a gray milky color. This seemed odd, since every manual transmission (Audi) I have replaced the fluid on, the draining fluid is dark brown. I thought perhaps the color may have been inherent in that of the previous fluid. As such I replenished the fluid and drove the car perhaps 1000 miles before, flushing and replacing with new. The photo attached shows the color of the draining fluid (same in both instances). In both instances I replaced the fluid with Castrol 80/90, per Bentley. Is this color a sign that detrimental wear (aka imminent gearbox rebuild) is occurring or is this coloring something that can be expected?
Note the drain plug magnet did have very fine metal deposits attached, no alarming amount, but no metal chunks.
Old 01-08-2016, 07:32 AM
What?
Eric Hahl's Avatar
Sounds like moisture.
________________________________________
Eric Hahl
85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD)
2015 981 Cayman S (Sold)
23 Outback Wilderness & 23 BMW R1250GS
Old 01-08-2016, 07:34 AM
85911's Avatar
^ Whenever I have gotten water in any oil, it turns to a chocolate milkshake color.
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold
Old 01-08-2016, 07:36 AM
Where would the water come from?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 01-08-2016, 07:37 AM
kmoush's Avatar
The car now resides in San Diego, and has not been driven in any rains....definitely not in the current El Nino.
Old 01-08-2016, 07:42 AM
KNS KNS is offline
I hope this isn't the case but if the car was in a flood/high water it could get in through the upper breather.
Kurt
kmoush's Avatar
For that to happen I would assume the car would have exhibited some signs of water damage in the interior. I did not see anything like that when I pulled the interior and detailed the interior and all the carpets. But I could be wrong.
Assuming it did not encounter such hi water, I am still baffled by the color, and if air moisture were the culprit it seems odd it would have this drastic affect.
Old 01-08-2016, 07:49 AM
Where did the car come from?
Sounds like it could be condensation build up from a lot of short trips where the gear box never reached a high enough temp to boil off the condensates that form inside.
Do you know how long the fluid had been in there?
Scott
'78 SC mit Sportomatic - Sold
Old 01-08-2016, 07:54 AM
kmoush's Avatar
Photo of draining fluid.
Old 01-08-2016, 08:00 AM
kmoush's Avatar
The original owner, Menlo Park CA, second owner LA (owned car for 13 months) now myself in San Diego.
I do not know how long the fluid was in the car originally. Between the changes I did, 5 months and about 1000 miles.
Old 01-08-2016, 08:03 AM
Diss Member
Quicksilver's Avatar
The moisture came from the air. The case is vented to the atmosphere. The case cools during the evening and during cooler weather condensation will form inside the case. Once that condensed water gets into the oil it will tend to go towards the bottom where it can't evaporate again.
The process repeats everyday as new air is pulled in when the temperature drops in the evening. Any vented lubrication system will gather moisture unless it is heated regularly to boil it off.
Once the water is in the oil the churning action of the moving parts will emulsify the water and oil and it will appear milky.
What you have is a car that probably wasn't stored in a heated garage and it wasn't driven regularly to heat the gear oil to the point where the water would boil off. If it came from a cold climate that will greatly increase the chances of this happening.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-08-2016, 08:06 AM
kmoush's Avatar
Yes, I would tend to agree water in the fluid can lead to that color as a result of emulsification.
I have to assume this is something that is a non issue. Having worked in Stuttgart for 3 years and experienced the crazy amount of cold, rain and moisture in So. Germany, and the fact that the majority of Germans don't have garages, and would never think of having a heated one, this issue would be expected and engineered into the design.
Now that the car is in SoCal the affects of this should be not as prolific.
Thoughts?
Old 01-08-2016, 08:19 AM
Member 911 Anonymous
DRACO A5OG's Avatar
OP, did you warm up the car before draining or cold?
I personally like to drive her around prior to gear box lube dump.
'85 Carrera Targa
PCA/POC
Old 01-08-2016, 08:56 AM
kmoush's Avatar
Yes, the second time I had to drive 45 minutes (all freeway) to the lift where I did the draining (car on lift in photo).
Old 01-08-2016, 09:00 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Two possibly three ways for moisture to get into the gearbox.
1) Atmospheric
2) Driving under water, or splashing and bad seals, or combo of any or all.
3) Car/motor washing technique.
Highly unlikely other possibility, would be mechanical damage to the trans case.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 01-08-2016, 09:10 AM
DRACO A5OG's Avatar
Very Strange indeed.
I wonder what your next change will look like???
'85 Carrera Targa
PCA/POC
Old 01-08-2016, 09:13 AM
Diss Member
Thoughts?
You posted the pic while I was typing and what you have is jaw dropping. I would have to agree. I was expecting some milky streaks leading to a much darker color. It takes a lot of abuse to get that level of water in it. We used to see serious moisture (but still not to your level) during long cold snaps in Alaska. They would see repeated heating to around room temperature followed by freezing. In the engines you would even see what looks like brown/grey pudding collecting inside the valve cover from the quantity of water building up.
I would guess that water was directly introduced. I wonder if the vent was exposed to a power washer or something. It is good that you got it out of there because you don't want the transmission corroding on the inside. I would have the vent checked. If there was a "normal" leak in the upper trans such as a pad gasket or seal, I would expect there to be a very obvious leak of trans fluid.
The only other source I can think of besides the vent is if it was actually put into the trans. Either sabotage or maybe someone cheaped out and drained the fluid into a container that had some water and the refilled the the trans from that container. Seems like a longshot but what you have is breaking the "Odd-O-Meter" already.
One thing you will want to do is go on an extended hard drive to seriously heat that trans and "boil" it out. (A great excuse for a track day!)
Old 01-08-2016, 09:16 AM
Get a little pump and pull some oil out now (from the fill port) and see what it looks like. Assuming it is relatively fresh, you can check it like this every so often to see at what rate it changes. It should, at this point, be showing few signs of water emulsification. As DRACO says, be sure to warm it up before you sample it (but be careful not to burn yourself). Also, be sure you didn't put in limited slip oil unless you have a LSD (Castrol makes 80/90 for LSD). If it already is milky, something strange is going on...Good luck.
Lyle.
Old 01-08-2016, 09:23 AM
gearhead
You have a blown head gasket...
Sorry. I've got nothing. This is a weird one. Once could be explained. Number two time just doesn't make sense.
What was in it before? Redline Shockproof? All the calcium in that junk comes out of suspension and leaves crud all over inside the gearbox. That's the only thing I could think of that would make it happen twice.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-08-2016, 09:47 AM
kmoush's Avatar
Cannot be the head gasket.....I fixed that with some JB weld. Miracles!!!
I do not know what was in the gearbox when I bought the car, however both times I put in Castrol 80/90W, and not "limited slip", followed the API specs mentioned in the Bentley.
Yeah this one has me stumped.
Old 01-08-2016, 10:11 AM
Tags
915 gearbox , gearbox fluid , transmission fluid
