Help on oil leak
Anyone hav any info on how to approach this leak?
I believe it is the cam oil line It is 1983 911sc with a 3.0
Bump
83 SC
I believe there's a copper crush washer that seals that line, between the line and cam housing. I believe PP sells that and it's an easy fix by simply loosening the nut, replacing the crush washer, and re-torquing. Tim
83 SC
Looks like that oil line has 2 crush washers. Part number 900-123-115-30-M127, but PP may be out of stock. I'd give them a call and verify. Good luck.
thanks you guys!!
Member 911 Anonymous
Just do not over torque it.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
