Hood Support Struts
My front hood struts don't support the weight of my frunk hood (1983 SC) - they start drooping. So I thought I would replace the struts. Just received new struts from SunCoast - genuine Porsche parts (911 511 331 00).
My question is how much pressure should it take the compress these. Try as I might, I can't get them to push it, even slightly. The Bentley manual says during install to 'while compressing strut slightly, ...' - so I'd rather not get that far before figuring out something is off with these? Any guidance - thanks! I thought I was clever buying the Porsche part rather than the Weltmeister from Pelican - but perhaps that was a mistake. Struts weren't cheap - so need to know whether to send back. |
No, you won't be able to compress them by hand. Once you get the bottom pin in, you'll have to lift the hood up a little higher than it normally sits to get the top pin to line up, but once it's in everything will settle properly. I purchased the Stabilus Heavy Duty shocks from Pelican for $14 each. They are great. I found that one of these supports the hood by itself, so it makes installation of the second one very easy. Use a board or something to support the hood while you're installing the first one.
_______________ John 1988 Carrera Targa 3.2 G50 - Sold. 2017 Chevy Silverado K1500. |
It is an easy job for the passenger's side. The driver's is a bit of a challenge since there is no room to get your hand in there on the bottom.
If by chance there is a clip it is easy to slide it off. It is a royal pain to get it back on. I would bet the vast majority of folks never put the clip back on for the bottom pin. It is not a problem to NOT use the clip. The pin stays in place without it. Like John said above, just lift the hood a tiny bit more than normal and the pin goes right in no problem.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Thanks guys. I need to pick up a hemostat/forceps then will tackle the project.
I think mine will be one of those without the clip on the bottom pin on the driver's side.
1983 911SC 2005 911S |
RETIRED
You don't need the bottom clip on the driver side. Trust me.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
I tied dental floss on the bottom clip on the drivers side to fish it out the 15 or so times it fell before clipping in properly. Tip learned on a previous pelican thread.
Undocumented User
A driver's side clip not installed is a job half done.
RETIRED
OH SNAP!
I'll get over it. ![]()
6 cylinder symphony
Ha -
I haven't had a d/s clip for 4 or 5 years! And I don't plan on installing one.
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
Thread Tools | |
Rate This Thread | |
