-   -   3.6 Throttle Linkage Set-Up Question (http://forums.pelicanparts.com/porsche-911-technical-forum/89793-3-6-throttle-linkage-set-up-question.html)
3rd_gear_Ted 05-28-2017 03:54 PM
Originally Posted by Mahler9th (Post 9604651)
I think that one of the best ways to address small angle throttle response/pedal travel issues is the change the geometry. One of my friends (who built my car and builds my engines) suggested this t me years ago. In my case, the change was made on the lever on the transmission pivot. I lengthened it quite a bit.
My friend has done this mod to a few cars.
Very easy to do.
I don't think the conversion to a cable set up changes geometry by itself.
This is what I had to do to get full throw of the throttle plate, but most importantly in the added throw is definite actuation of the WOT micro switch that provides full throttle mapping to the fuel injectors. Now my S. Wong chip and my 3.6 works like advertised.
Sooner or later 05-28-2017 04:04 PM
Originally Posted by widebody911 (Post 617699)
In this image, you can see my okiefication of the linkage:
http://vintagebus.com/howto/trans-cooler/legend.jpg
Hey! I'm an Okie.
AllardK3 05-28-2017 08:40 PM
So what modifications are needed to the 964 cable to make it work with an SC pedal?
arrivederci 05-29-2017 09:30 AM
I had the bicycle cable with the lengthened arm at the trans pivot. I thought it felt terrible so I found a thread on the 964 cable mods. I don't remember what exactly I had to change. It involved some copper fitting from the hardware store and removing part of the cable housing (which was a pain). Works awesome now!
faverymi 05-29-2017 01:56 PM
I have no cable system. It was terrible.
SC accelerator console that mounts perfectly in the 964 cruise control location.
From there a modified in lenght accelator rod that attaches to TB butterfly.
Voila. Perfection. No drag no issues. Just right
arrivederci 05-29-2017 04:02 PM
Here ya go...scroll down in this thread.
http://forums.pelicanparts.com/porsche-911-technical-forum/308212-how-convert-throttle-linkage-3-6-transplants-3.html
froggert 05-31-2017 07:46 AM
I have the Patrick cable. It's super smooth, but pedal travel is really long. I wish there was a way to easily shorten it.
AllardK3 06-01-2017 07:39 PM
Thanks for the info guys! I think I am going to go ahead and fabricate my own from the bellcrank back. I want to get a little quicker initial opening, so I will play with the motion ratios a bit.
Mike
AllardK3 06-18-2017 09:23 PM
Thanks for the help and info. I made a new throttle cable and bell crank with better motion ratios. (Lokar 36" throttle cable kit).
The difference is huge. Much better throttle response and easier to match the downshifts. One of the best mods I have done. Strongly recommend it!
Mike
