Hood Support Struts
My front hood struts don't support the weight of my frunk hood (1983 SC) - they start drooping. So I thought I would replace the struts. Just received new struts from SunCoast - genuine Porsche parts (911 511 331 00).
My question is how much pressure should it take the compress these. Try as I might, I can't get them to push it, even slightly.
The Bentley manual says during install to 'while compressing strut slightly, ...' - so I'd rather not get that far before figuring out something is off with these?
Any guidance - thanks!
I thought I was clever buying the Porsche part rather than the Weltmeister from Pelican - but perhaps that was a mistake.
Struts weren't cheap - so need to know whether to send back.
Old 01-08-2016, 10:45 AM
No, you won't be able to compress them by hand. Once you get the bottom pin in, you'll have to lift the hood up a little higher than it normally sits to get the top pin to line up, but once it's in everything will settle properly. I purchased the Stabilus Heavy Duty shocks from Pelican for $14 each. They are great. I found that one of these supports the hood by itself, so it makes installation of the second one very easy. Use a board or something to support the hood while you're installing the first one.
_______________
John
1988 Carrera Targa 3.2 G50 - Sold.
2017 Chevy Silverado K1500.
Old 01-08-2016, 11:01 AM
It is an easy job for the passenger's side. The driver's is a bit of a challenge since there is no room to get your hand in there on the bottom.
If by chance there is a clip it is easy to slide it off. It is a royal pain to get it back on. I would bet the vast majority of folks never put the clip back on for the bottom pin. It is not a problem to NOT use the clip. The pin stays in place without it.
Like John said above, just lift the hood a tiny bit more than normal and the pin goes right in no problem.
Old 01-08-2016, 11:22 AM
Thanks guys. I need to pick up a hemostat/forceps then will tackle the project.
I think mine will be one of those without the clip on the bottom pin on the driver's side.
1983 911SC
2005 911S
Old 01-09-2016, 08:20 AM
RETIRED
Joe Bob's Avatar
You don't need the bottom clip on the driver side. Trust me.
2012 ML350 3.0 Turbo Diesel
Old 01-09-2016, 08:27 AM
I tied dental floss on the bottom clip on the drivers side to fish it out the 15 or so times it fell before clipping in properly. Tip learned on a previous pelican thread.
Old 01-09-2016, 12:20 PM
Undocumented User
McLaren-TAG's Avatar
A driver's side clip not installed is a job half done.
Old 01-09-2016, 12:54 PM
RETIRED
Joe Bob's Avatar
OH SNAP!
I'll get over it.
Old 01-09-2016, 01:07 PM
6 cylinder symphony
Ha -
I haven't had a d/s clip for 4 or 5 years! And I don't plan on installing one.
'84 3.2 Targa
'89 964 Coupe
"What do you mean NEXT project?" - my wife
Old 01-09-2016, 02:49 PM
