coils
greetings, the coils are part of the Rasant Engine Management kit and are Bosch part number 0 986 221 024.
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
farteeest
Thanks Rich.......for the kind words. I appreciate it.
regards, al
2.7 build
I like the 2.7s too............and 2.2s....3.0s, 3.2s....3.6s......you know what i mean.
https://www.youtube.com/results?search_query=koz77911 regards, al
Al, project looks great!!! Are you still using the Triumph Speed Triple throttle bodies?
When are you targeting your first fire? The Rasant kit uses the AEM Infinity ECU. You tune via a Windows laptop and USB connection. I have a good friend tuning his with a Macbook Pro and the Windows emulator it comes with and its working fine. You can log to USB and download afterwards, or log direct to the laptop. |
questions
I chose 9.5:1 JEs because they provide higher compression without requiring twin-plugging. These pistons are good for carbs and EFI applications and have pockets deep enough for hotter cams. I really like early e-cams for their overall characteristics....so i chose a cam very similar to early E, but with higher lift more compatible with the larger 3.0 engine. combined with headers and sport exhaust...this is a great combo for the street/canyon carver.........it is a hot rod engine, but not over the top and over-stressed. should work fine and last a long time..... But that's just my preference....and I debate this stuff endlessly with my peeps........you might have a different use for your 911 and want higher compression, twin-plug,,,,much hotter cams etc.........lots of choices, but in my mind, you need to decide what you like/want .....and why....then define the system.
Beautiful setup.
Are those coils fastened to the valve covers in any way? |
COPs
regards, al
minor update
Installed the heater backdate ducts and the headers and adjusted the T'body linkage.........the last of the fuel plumbing fittings are due tomorrow and then i will move this engine to the test stand.......
![]() regards, al
If required, i think those would work very well.
Thanks. al
I would be wary of using those retainers if not absolutely necessary. I've tried them and they do not fit correctly inside the cover's recessions and do not allow you to properly torque the covers. What I ended up doing is changing the cover's studs for longer ones and torquing the covers with a set of security nuts and placing the plug retainers on top with another set of nuts, this gave the retainers sufficient clearance over the cover's recession and allowed me to have them properly set and torqued without the possibility of loosing torque when moving the retainers.
"With an stock-original car, you serve the car. With a hot-rodded car, the car serves you." |
I do not plan to use them unless necessary, but due to the height of the COPs, a longer stud or threaded space will be required............... anyway, not an issue at this time.......... regards, al
Excellent job Al, as usual. Could you share, in round numbers, what the parts cost of such a project runs? This is the engine I'd dream of for my '74.
Thanks! -C
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
This is just plain sexy!!! I can't wait to hear that motor in a car at full song!!!
~A
1983 Porsche 911SC Blk/Blk 1956 Ford F1 - Patina 2013 Toyota Tundra 4x4 5.7 2013 Honda Pilot Last edited by APachon71RN; 02-17-2016 at 02:50 PM.. |
Here's my kit on a very nice 3.2 tarmac Rally 911 (stock 3.2) originally located in Portugal (AlexJ on Pelican) and then sold to the guy who made the pro video. https://www.youtube.com/watch?v=enRgZ4FUNB4&feature=youtu.be My S3-EFI/ITB kit installed on the 3.2 SS engine in the DZUG boys tour car in north Carolina.(headed for Sicily) https://www.youtube.com/watch?v=pxXwaL_TdmY https://www.youtube.com/watch?v=xaj0FyEmc68 regards, al
Sounds EPIC!!!
~A Quote:
1983 Porsche 911SC Blk/Blk 1956 Ford F1 - Patina 2013 Toyota Tundra 4x4 5.7 2013 Honda Pilot |
I want to stay up to date with this thread. how do I "subscribe"?
Extremely Yellow ’74 Targa 2.7 L - aka WIFE’S BANE |
scroll up to the top of the page and in the upper right hand corner....click on 'Thread Tools"
numbers
The numbers related to this particular build are specific to the new owner, but I'd be glad to discuss numbers with you, in general...if you will pm me with your email address. regards, al
Great project, my question is, if you are running headers how are you going to use the backdated heat? Dave |
