Dial 911
A horse with no name's Avatar
OEM Euro Pre Muffler sound comparison..
Hi, I was wondering if anyone has a Euro Pre Muffler...What does it sound like with a 1 in and 1 out? Is it similar to M&K's, a Dansk...Or?
Thanks in advance
Cheers!
“Simplicity is the ultimate sophistication.”
Leonardo Da Vinci
Old 09-25-2015, 05:59 PM
Thanks in advance
It's basically identical to the Dansk, except the Dansk is stainless steel vs mild steel for the Euro pre muffler. The Euro also doesn't have an O2 sensor bung. I think Dansk may have built the premufflers for PAG.
I have a Dansk premuffler/cat bypass on my 3.6 with a Dansk sport muffler. Sounds
great. Not loud at all, but has a nice rumble at idle and a nice power sound when you get on it!
Here's a Dansk
Here's a factory Euro pre muffler. Looks like it had a O2 bung retrofitted.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 09-25-2015, 07:27 PM
911SC Tinkerer
merlinfe's Avatar
Depends on your muffler choice for noise. Performance wise, when I installed mine I noticed the engine breathing better and reving freely all the way up to redline. The reduced back pressure from the loss of the catalytic converter also meant a mild loss of low to midrange RPM torque. You can hear the burps and gurgles on coast down better with the exhaust opened up as well.
Stock early Pre-Mufflers will come without an O2 bung, but one can be welded in for around $50 from a muffler shop. Just tell them where to put it and make sure you bring an old O2 sensor so they get the thread size right. The issue with this is your O2 sensor only "sees" one bank of 3 cylinders. Dansk units will collect gases from both banks and give the O2 sensor a better average.
I have a pretty free flowing M&K exhaust, so your results will be different with a different muffler set up. I had similar results with a B&B style magna flow set up.
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 09-26-2015, 08:46 AM
Dial 911
Thanks everyone for the info - I guess it will be a Dansk or M&K
Thanks everyone for your info - I guess it will be a Dansk or M&K...Again- Thanks!
Cheers!
Leonardo Da Vinci
Old 09-26-2015, 07:21 PM
rnln's Avatar
what I know is the euro premuffler have diff diameters on the inner perforated tube. It came in smaller then becomes bigger diameter at the end. This is why it reduce a lot of noise? even when you speed up at high RPM (compares to any other with straight pipe or straight inner perforated core/tube)
Fat butt 911, 1987
Old 01-13-2016, 01:30 PM
Dial 911
Cool Info update
Just some info re what I chose to go with...I would have preferred the M&K pre muffler but with our Canadian dollar dropping so much, due to the low price of oil, I ended up purchasing the polished SS Dansk. (our dollar is now worth 30% less than the US $)
I have a SS B&B performance muffler and now coupled with the Dansk pre muffler, the sound is basically what I wanted. It sounds great when idling and it is not 'loud' nor is there any droning at highway speeds. As Merlinfe stated, the burbs and gurgles do sound great when slowing down for say a stop sign.
When I installed the Dansk I also purchased a chip from Steve Wong. I should have maybe driven it with just the exhaust update before installing the chip to see what the difference was between them. I do though now have a very big smile when driving it as the performance is quite amazing due to having the sports muffler, pre muffler, with Steve's chip.
All that I can say now is Wow! - What a difference!!
Cheers!
Leonardo Da Vinci
Old 01-13-2016, 02:20 PM
Member 911 Anonymous
DRACO A5OG's Avatar
It is definitely quieter than the M&K or straight pipe Cat By Pass.
Per Rnln, after installing at his house, we were both surprised at how much quieter it was compared to the M&K.
I have my air box cut up so at higher RPMs, she starts to scream louder than stock set up.
'85 Carrera Targa
PCA/POC
Old 01-13-2016, 02:58 PM
911SC Tinkerer
merlinfe's Avatar
Glad you like the new set up! I just finished the install on SSIs and a Dansk GT3 2in2out. The sound is nasty.
-Steve
Old 01-13-2016, 03:22 PM
DRACO A5OG's Avatar
Nasty Girl Love It!
'85 Carrera Targa
PCA/POC
Old 01-13-2016, 05:54 PM
