toddu's Avatar
Build up on intake valve
I have about 1000 miles on a new rebuild. I took the carbs off due to some running issues and looking down the intake I noticed a bit of oil behind the valves and a fair bit of buildup on the backs. What could be causing this?
Todd
'81 SC
Old 01-23-2016, 10:36 AM
Incorrect valve stem seal replacement? Improper installation or incorrect seals.
Old 01-26-2016, 07:56 AM
toddu's Avatar
I suppose that could be a possibility, but I would hope not as the engine was rebuilt by a very reputable shop.
The car has sat for weeks, not sure if that matters. When it sits I get a bit of smoke for probably less than a minute, but no smoke under normal driving.
Todd
'81 SC
Old 01-26-2016, 08:54 AM
tharbert's Avatar
There was a fairly recent thread by Mike (VFR750) where he was concerned about oil puddling on the valves. The heads were done by a reputable shop, the same as did mine so I watched his thread closely. He also had a long thread about ring break-in as well.
What kind of break-in procedures have you used?
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 01-26-2016, 09:06 AM
db_cooper's Avatar
Just be sure you are not keeping the oil level too high..or checking the oil level when the engine is not completely warmed-up and running.
Any excess engine oil will end up in the intake manifold and on the valves.
My 911s like the oil level right in the middle of the dip-stick range..engine hot, at idle and on level ground. The engines like to "blow-off" that first 1/2 to 1 quart if you keep the oil level at the MAX mark.
Old 01-26-2016, 11:20 AM
Are you sure its oil? perhaps it is gas.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 01-26-2016, 11:27 AM
toddu's Avatar
It's a carb'd engine if that makes a difference.
No, I'm not at all certain it's oil. I took the carbs off as I'm having issue with the car running. In fact, I couldn't get it to start a couple weeks ago and yanked the carbs this past weekend. I thought about gas myself because of the starting issues, but it's pretty dark.
I have tall manifolds (left those on when removing carbs), so a little difficult to check.
Motor was dyno'd after build, so rings should have seated then.
Todd
'81 SC
Old 01-26-2016, 11:44 AM
