Oil change question with pics.
First time changing my oil on my 1988 (non turbo).
When I pulled my engine oil plug, I failed to notice which way the spring set up was installed.
Please look at pics
This way?
or... this way?
thanks
Old 01-18-2016, 10:50 AM
Member 911 Anonymous
DRACO A5OG's Avatar
WTD? where exactly did you remove this from?
Please post a pic of the bottom of the car.
'85 Carrera Targa
PCA/POC
Old 01-18-2016, 10:52 AM
Crotchety Old Bastard
RarlyL8's Avatar
You pulled the wrong plug, that is the oil bypass valve.
Pelican probably has a schematic.
Old 01-18-2016, 10:56 AM
DRACO A5OG's Avatar
and per PAG schematics, first picture is the orientation.
Look up the torque specs, do not over tighten it or you will have a permanent oil leak or worse damage the casing.
'85 Carrera Targa
PCA/POC
Old 01-18-2016, 11:08 AM
Thank you sir!...and will do on the torque specs.
Old 01-18-2016, 11:12 AM
DRACO A5OG's Avatar
Please look or download from PAG your 3.2 Katalog, so you can verify for yourself.
'85 Carrera Targa
PCA/POC
Old 01-18-2016, 11:18 AM
French Import
zippy_gg's Avatar
And replace that crush washer...
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 01-18-2016, 11:37 AM
That's the oil pressure relief valve not the drain plug. When you reinstall it the brass piece sits in the plug to support the spring.
Old 01-18-2016, 01:45 PM
