My speedometer still reads with sensor disconnected!?
I've been trying to diagnose my speedometer on my 930 for several weeks now (reading too slow, never going above ~60mph). In my attempt to diagnose the sensor that is attached to the side of the differential and the magnets and connections to the sensor, I disconnected the wires to the sensor on the differential completely and went for a ride. To my surprise the speedometer needle was still reading and moving and changing with speed of the car(although still reading incorrectly)! I was expecting the needle to not move at all, or be stuck at some constant speed. How can the speedometer be getting any kind of reading if the sensor is completely disconnected at the differential?
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... |
was the tach working?
Yes, tach is a totally different gauge and working fine. Odometer is also unrelated and working fine. Only the speedometer has issues. Rather than trying to find out what is wrong with the speedo or sensor, now I'm wondering how a speedometer can move and sense some kind of speed if the sensor is totally disconnected.
83 911 Production Cab #10
GPS version...
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
non-whiner
The tach question was a valid one. Tach pulses can cause erratic speedo behavior. Has anyone been behind your dash? Has it always done this or did it just start recently?
"Too much is just enough." |
That's a weird one.
Did you disconnect the sensor wiring at the transmission/tunnel or did you disconnect it at the speedo? Can you post a picture of current wiring to the speedo? |
My speedo showed activitiy while it was disconnected at the tunnel. Almost followed the tach and bounced a bit. When i reconnected the wires in the tunnel all was normal again.
1982 911 Targa, 3.0L ROW with Webers |
Here are some pics of the wiring at the speedo. I have checked all the connections at the speedo and they are fine (removed and reattached). The speedo readings were fine before, just a few months ago started showing slow speeds and maxing out at about 50-60 mph. I thought it was a sensor issue or the magnets that spin, but this reading with the sensor completely disconnected has me puzzled. ![]()
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... Last edited by jwakil; 01-01-2016 at 09:48 AM.. |
The wiring to the sensor was already open somewhere?
Electronic pulse "counters" will do, can do, strange things with an open sensor circuit. |
non-whiner
Which pin of the sensor inputs is grounded? This sounds like a ground issue or lack there of on the sensor inputs to the speedo. Check it with a multimeter with the sensor inputs disconnected at the speedo.
ROW '78 911 Targa
Disconnect the Red/Black wire (Gauge Power) and it should stop moving.
The 2 Brown/Red wires are from the speedo sensor. No idea what the white wire with a non standard connector on it in your photo is for. Any idea as to where it goes/coms from?
I recommend disconnecting the 2 brown/red wires from the speedometer and then checking continuity to ground on each with the speed sensor disconnected. Also check continuity between the two wires. Any continuity indicates a short somewhere, which may affect the counter circuit of the speedometer.
non-whiner
That white wire, as Dennis pointed out, is suspect.
I think you might have disconnected the backup lights not the speedo
Banned
[IMG]http://www.*****************/uploads/images/product/ABS%20sensor/91160620901lr.gif[/IMG] Last edited by Ronnie's.930; 01-01-2016 at 09:38 PM.. |
ROW '78 911 Targa
Speedo wires are disconnected at the rear tunnel access hatch inside the car.
I have also never messed with the wires on the speedo itself. The white wire has always been there and the speedo worked fine for 3 years.
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... Last edited by jwakil; 01-01-2016 at 10:24 PM.. |
Ok, maybe I did disconnect the wrong thing. Here are a couple of pictures of what I disconnected (the white round thing with hex nut and two wires attached, the lower one is a white wire, and the upper which only shows the blue connector is a brown wire).
![]() ![]() After searching some more, I found what I think might be the actual speedo sensor (below): If this is the case, then what is in the above two photos?
81 -930 82 - Austin Mini 998 78 Mini 1275cc -totaled 83SC Euro w/77 3.0 Carerra Eng.--sold Several other daily drivers not worth mentioning... Last edited by jwakil; 01-02-2016 at 12:05 PM.. |
Banned
The first two photos are the switch for the reverse lights.
And yep, the last pic is the speedometer sensor. The wire connectors for it are inside the car, beneath the cover plate for the shiftrod coupler (in front of the rear seats). |
Crap, I wasted a lot of time looking at the wrong thing. Is the actual speedo sensor just press fit in? After checking the wiring, the next step will be to remove that and clean the magnets behind there. Do you just pull it right out?
