BReyes's Avatar
Caster settings?
Caster settings?
Curious, what are the caster settings range on the track? I'm saying front camber box and rear adjustable box too.
Tires ... say: 265 40 18s / 315 30 18s on Fikses.
Regards,
Bernard
Old 12-05-2006, 07:44 PM
Usually max available is recommended, but I don't know if that would hold true for someone with a camber box (assuming much more than stock is available with camber box) and for such large tires. I believe it still would be, but I'm not certain.
Old 12-05-2006, 08:14 PM
It might also be a good opportunity to get rid of some caster too.
Big rubber up front with lots of caster might make you wish you had power steering.
I have my caster set to 2 1/2 degrees with a fair amount of grinding, resulting in effortless steering and still has good on center feel without any loss in stabilty.
Cheers,
Joe
74 w/ 86 3.2
Old 12-06-2006, 06:56 AM
