-   -   MSD Coil Ballast Resistor Needed? (http://forums.pelicanparts.com/porsche-911-technical-forum/900715-msd-coil-ballast-resistor-needed.html)
scarceller 02-08-2016 06:40 AM
I'm assuming this is a factory CDI ignition? In CDI the coil acts as a step up transformer and NOT a storage inductive device. I don't think the MSD coil was intended for CDI, I could be wrong but no matter I suggest you go back to the stock coil. It's possible that the MSD is simply pulling to much current from the CDI box.
Originally Posted by Sunroof (Post 8989360)
.....You are right about the silver Brazilian made coils in that two failed in my 1973.5T. I had a hard time finding any suitable replacement until a few folks mentioned the MSD Blaster coil, which I bought. Now I am experiencing intermittent "sudden shut down" that may be attributable to that coil that may be contributing heat to the CDI unit. Please correct me if I wrong here...................the CDI unit was recently rebuilt, I use a 6500 limiting rotor, standard points and this MSD Blaster coil. After a long ride, the car shuts down!!!! After a long cool down it runs again. Wrong coil? rotor?. I just ordered the original black replacement (not the silver one) from a shop in Arizona, so I hope that helps. Other have stressed to use a "non-resistor rotor".
Bob
mreid 02-08-2016 06:49 AM
Any one of these, with the Pertronix being the best choice, will work better than the msd:
Ignition Coils - Universal - Canister Coil Style - 3.000 ohms Primary Resistance - Free Shipping on Orders Over $99 at Summit Racing
mysocal911 02-08-2016 06:56 AM
Actually it's the opposite of that, i.e. since the MSD has a higher inductance the SCR in the CDI
will have less peak current. The spark duration will be a little longer, but the peak voltage
will be the same i.e. assuming the turns ratio is about the same - 100:1.
Remember: In most cases an inductive discharge ignition coil can be used in a CDI application,
but a CDI type coil can't be used in an inductive discharge type of ignition.
mysocal911 02-08-2016 06:58 AM
Primary resistance = 3000 ohms - NOT GOOD
Plus no other data, e.g. turns ratio.
scarceller 02-08-2016 07:05 AM
Dave,
This shows the data for that coil
PerTronix Flame-Thrower Ignition Coils 40511 - Free Shipping on Orders Over $99 at Summit Racing
The coil shows 11mH inductance
3 ohm primary
mysocal911 02-08-2016 07:31 AM
Originally Posted by scarceller (Post 8989386)
Dave,
3 ohm primary
Decimal point looked like a comma with all those zeros, i.e. why show three zeros
when the accuracy is probably valid to only one decimal place?
And 11mh is way too much even for an old points ignition system, i.e. not a good replacement coil!
scarceller 02-08-2016 07:41 AM
Dave,
The stock 3.2L and 964 coil is Bosch part # 0221118322 would you happen to have the specs for this coil?
I have 3 of these black coils and 1 silver one, I've measured the following with ohm meter:
Primary - 0.6ohms
Secondary - 6000 ohms
I assume a 100:1 turn ratio?
I've also seen ref to 3.8-4.0 mH?
Do you have any formal detailed specs for the coil? or can you confirm the above info?
Thanks.
mysocal911 02-08-2016 08:10 AM
Originally Posted by scarceller (Post 8989426)
Dave,
Primary - 0.6ohms
Thanks.
Check the link in post #8 as there are multiple coil values provided including the 993's.
The Bosch TCI value should be the same for both the 3.2 & 964. I haven't verified those values provided, though. Your resistive values you measured seem to agree with the Bosch TCI values
on that website.
scarceller 02-08-2016 08:20 AM
Thanks for the link that helps.
I noticed the 993 coil spec at 3.1mH vs the TCI spec at 3.6mH I know folks have used 993 coils with the 3.2L setup. This data indicates you would be likely over driving the 993 coil if used in the 3.2L?
Once again thanks.
on that website.
wwest 02-08-2016 08:40 AM
Bob
The primary concern is about non-OEM coils being used with '83+ DME inductive ignition systems. With those the dwell time is controlled in accordance with the parameters, inductance, etc, of the factory coil. So some care must be taken if replacing the factory coil.
As long as you still use resistive HV wire and plugs I would encourage switching to a non-resistive rotor.
Buy a can of Kool-spray at Radio Shack and the next time the system quits spray the CDI to cool it down. If spraying the CDI doesn't work....
When my '78 did this I used a light spray from a garden hose to isolate the failure to the CDI.
rick-l 02-08-2016 08:44 AM
What does TCI stand for?
rick-l 02-08-2016 08:49 AM
Originally Posted by wwest (Post 8989519)
blah blah blah
You can't give advice till you tell me how that transformer works.SmileWavy
wwest 02-08-2016 08:58 AM
You just qualified for my ignore list, a FIRST!
wwest 02-08-2016 08:59 AM
Improve Bosch OEM CDI spark power by a 1.6 multiplier, ~24mJ vs ~15mJ, for less than $75.
Accel 140008 Electronic Super Coil Ford GM for Electronic Computer Ignition | eBay
http://forums.pelicanparts.com/uploa...1450041704.jpg
rick-l 02-08-2016 09:02 AM
This is all I have to measure inductance.
50 year old precision capacitor...yeah right. Now I've got to go buy 6 D cells.
http://forums.pelicanparts.com/uploa...1454954285.jpg
mysocal911 02-08-2016 09:10 AM
The same website defines it here: Glossary
mysocal911 02-08-2016 09:18 AM
Once again thanks.
Possibly, but that coil would need to be tested under all battery voltages provided before
in this thread, e.g. 8/12/16 volts. The 3.2 DME ECU current limit would limit the current if the
993 coil saturated, i.e. because of lower inductance.
rick-l 02-08-2016 11:31 AM
Holy Crap... That driver dissipates some power
Hey Sal what am I missing here?
4 mSec dwell ???
The green trace is the current through a 3.6 mH inductor. System voltage is 13.5
The red trace is the instantaneous power in the driver. (106 W Peak???)
The integral of the red trace is 184.36 mJ
At 900 RPM idle that works out to 8.3 Watts (22.22 mSec)
At 4000 RPM idle that works out to 37 Watts (5 mSec)
3-4 mH doesn't make that much difference.
http://forums.pelicanparts.com/uploa...1454962530.jpg
scarceller 02-08-2016 11:38 AM
Rick,
I'm not sure about the inductance of that coil, which is why I asked.
What I am sure about is:
1- that the DME activates the coil for a target of 4ms
2- when I bench test the coil it indicates that's the peak saturation point for that coil.
Those 2 tests are for certain.
How did you come up with the graph?
Let's work backwards with your graph: how many mH would be required to have the saturation (peak current) occur at 4ms? Does that make sense?
As I said I've never seen a formal Bosch spec for the coil, that's why I bench test to figure out saturation points.
4 mSec dwell ???
scarceller 02-08-2016 11:49 AM
Rick,
I found this calculator
Inductor Current and Maximum Power Calculator
It says a 7mH coil would charge to 8Amps at 14v in 4ms, I think the 3.6mH inductance number may be incorrect?
rick-l 02-08-2016 11:50 AM
I forgot the 0.6 ohm resistor. That drops it a bit -- even more amazing.
80.108 mJ
3.6 Watts avg at 900 RPM
16 Watts at 4000 RPM
Only 66 Watts peak
Edit: That was just a LTSpice simulation. I don't know specs of the Darlington driver so it is just a modern transistor.
scarceller 02-08-2016 11:53 AM
But are you still saying that the coil reaches saturation in about 2.4ms at 14vdc? that's not what I see in car or in bench testing.
rick-l 02-08-2016 11:58 AM
If you add the 0.6 ohms in series with the inductor it hits the current limit at 3 mS, at 0.9 it takes the entire 4 mS.
scarceller 02-08-2016 12:07 PM
And the darlington transistor in the DME has two 0.1ohm resistors in parallel from ground to the emitter, that adds another 0.05ohms, right?
Your calcs based on an assumed inductance of 3.6mH still indicate that the coil may actually be/have a higher inductive value, right?
I know for sure that at 14vdc that coil hits saturation at about 4ms.
ischmitz 02-08-2016 01:16 PM
I think the SPICE simulation completely omits the fact that the Darlington transistor has a considerable voltage drop across its NPN junction. No way the coil ever "sees" 14V. What does the o-scope read when you measure between GND and pin 1 of the DME ?
rick-l 02-08-2016 01:54 PM
Sal
I was watching your video again and is the bottom trace that you refer to as ground through a resistor so it indicates current?
I am not simulating inductor saturation. This is where beyond a certain flux density the permeability of the core is reduced and causes the inductance to drop. I don't have any data to predict that.
I'm just looking at where it hits the current limit that I modeled in spice with an ideal inductor.
Below is current with 0.8 ohms in series with the inductor in brown, power in red (50 mJ integrated) and the collector voltage of the cobbled together Darlington in blue.
If anyone wants to play with the LTSpice file (.asc) PM me your address.
http://forums.pelicanparts.com/uploa...1454971100.jpg
mysocal911 02-08-2016 02:24 PM
Originally Posted by rick-l (Post 8989924)
Sal
Yes, you've forgotten that in your simulation, i.e. a very critical parameter!
Once saturation of the core (the point at which the flux no longer changes), the voltage
across the coil goes to zero and the darlington driver in the ECU 'sees' the battery voltage thus entering a high power mode, but the current will be limited by the internal current limiting circuitry.
mysocal911 02-08-2016 02:30 PM
Not really, probably about 1.5 - 2.1 volts.
Correct.
Vcoil ~= 14.0 - Vsat (darlington)
mysocal911 02-08-2016 02:37 PM
Sal should be able to easily determine the coil's saturation point by incrementally increasing
the dwell time while monitoring pin 1 of the DME ECM uses an EPROM emulator, i.e. tweaking
the microcode.
rick-l 02-08-2016 03:10 PM
So you let everybody spew three pages of L di/dt calculations over a period of days all the time knowing that this was not the limiting factor for a DME ignition?
Once saturation of the core (the point at which the flux no longer changes), the voltage across the coil goes to zero
scarceller 02-08-2016 04:14 PM
Dave,
I've done this already, with my EPROM emulator I can increase dwell time and watch voltage at DME pin 1, exactly as you say. The result is the voltage starts to go way up at DME pin 1 (knees upward) right around 3.8 to 4.0 ms this is exactly how I find optimal dwell time for any coil in car. I tweak the dwell map to do this.
Basically I've confirmed peak saturation time in car at about 4ms and it also matches the 964 bench test using the 964 ignitors at 4ms. In the end I usually don't tend to care all that much of the inductance value of the coil, I simply test in car by increasing dwell till the coil saturates.
I've also measured voltage drop across the coil's '-' and '+' posts, this also works. So long as I use a isolated ground scope test lead.
the microcode.
rick-l 02-08-2016 04:28 PM
The voltage going up at DME pin 1 would indicate the start of current limit, see V (col) in the last simulation. Core saturation would be indicated by an accompanying increase in current rate of change.
scarceller 02-08-2016 04:40 PM
Rick,
I think Ingo was correct to assume you'll never have full system voltage across the coil because of the darlington and 0.05ohm resistors within the DME. I think this is why that actual in car dwell time is somewhat longer. When I get a chance I'll scope pin 1 again to see what exactly the voltage drop shows. But as I recall we have like 1v drop even at very low current from ground to pin 1 while the coil charges.
What I see in car at pin1 is that the voltage ramps nice and linear, then it takes a sharp bend upward as the coil saturates, then it finally plateaus as the current limiting kicks in. I also see this in bech testing the 964 coils with the ignitors. Look at my video again, you'll see the sharp knee followed by the plateau.
https://www.youtube.com/watch?v=a7dFdIdsZeU
See the 3min25sec mark in the video, you can see the knee happen followed by current limit.
Most hi-end EFI systems like MoTec and BoschMotorSports outline this very method for finding peak dwell times. They make a big point to say 'it must be done in car' so it accounts for all the voltage drops in the final coil configuration. Now that statement I read really make sense.
mysocal911 02-08-2016 06:18 PM
Yes.
rick-l 02-08-2016 06:33 PM
If the lower scope trace is the equivalent to pin 1 on the DME note the similarity to the v(col) plot in post #66. The voltage gradually rises as the current through the transistor goes up until the current limit starts, it rapidly rises, and hits a plateau. Is that what the lower trace is, the collector of the drive transistor?
Any way to add a 0.1 Ohm resistor to measure current?
EDIT: if that is the collector voltage notice that the voltage (which indicates current) is pretty linear until it starts to current limit which would indicate the inductance is not changing much before it hits the knee. I would think the core would be made of a cheaper iron material and would soft saturate, not hard saturate.
mysocal911 02-08-2016 07:40 PM
Originally Posted by rick-l (Post 8990255)
I
Just open the DME ECU and monitor the current limit resistor voltage.
ischmitz 02-08-2016 09:01 PM
Just a note of caution: Measuring across the 0.05 Ohm shunt with an o-scope is not trivial. Most bench-top o-scopes are grounded to neutral and thus you can't simply hook the ground wire up to one side of the resistor. Your benchtop power supply is likely also grounded to neutral.
I use a Fuke 123 when I have a task like this at hand - it is battery-powered and thus I can connect the GND lead anywhere I want without having to pay attention. With a bench-top you either want to use a good current-probe ($$$) or do a 2-channel differential measurement (noise-prone).
Ingo
scarceller 02-09-2016 04:39 AM
That lower trace is the voltage at the coil's '-' (from ground to the '-'). In that bench test video I was using the 964 BIM ignitor so we are measuring the voltage across the BIM (from ground to the BIM's coil output that goes to coil's '-'). Once voltage starts to go up significantly across the BIM it means the coil is at or very near saturation.
I do the same type of test in car at DME pin 1 and see same type of behavior.
scarceller 02-09-2016 04:41 AM
Agree, I use a hi-quality Techtronix 2465 scope that has isolated ground on the input. Or I can do as you say 'diff between 2 inputs', either works on this scope.
Ingo
scarceller 02-09-2016 04:45 AM
Dave,
Can do this also, those 2 resistors are 0.05ohms so at:
1amp = 50mv
2amp = 100mv
4amp = 200mv
8amp = 400mv
Certainly within the ability of the o-scope to measure this.
I have a test DME, I can easily solder a wire to that location and scope that point.
