-   -   MSD Coil Ballast Resistor Needed? (http://forums.pelicanparts.com/porsche-911-technical-forum/900715-msd-coil-ballast-resistor-needed.html)
dicklague 02-11-2016 05:23 PM
Originally Posted by scarceller (Post 8994079)
Since the thread is about a possible aftermarket coil that may/could work properly, how about this one?
http://www.msdperformance.com/Products/Coils/Street/Strip/8253_-_HVC-2_Coil,_6_Series_Ignitions.aspx
It's a 'HVC-2 Coil, 6 Series Ignitions' from MSD, looks very different but here's the specs:
Turns ratio: 100:1
Primary resistance: .16 OHMs
Secondary resistance: 630 OHMs
Inductance: 3.5 mH
Maximum voltage: 44,000 Volts
Peak current: 450 mA
Spark duration: 450 uS
Weight: 3.75 lbs
Not cheap, runs about $200!
thoughts?
or this:
http://forums.pelicanparts.com/uploa...1455243733.jpg
rick-l 02-11-2016 07:35 PM
HVC-2 Coil, 6 Series Ignitions - 8253
Turns ratio: 100:1
Inductance: 3.5 mH
Weight: 3.75 lbs
thoughts?
I'd say no. The 0.16 ohms lets it charge really fast and because the coil resistance is low it makes the driver dissipate about 100 Watts when in hold mode. I don't know the specs for the proprietary Darlington in the DME but I doubt instantaneous Ptot is 100 Watts. You could change the dwell table.:)
Originally Posted by dicklague (Post 8994440)
That is part of a "Complete capacitive discharge ignition system for 4-6-8 cylinder race engines" part of Daytona Sensors CD-1 Ignition System. They don't give any data for it and I bet it is tailored for their CDI sytem
