-   -   MSD Coil Ballast Resistor Needed? (http://forums.pelicanparts.com/porsche-911-technical-forum/900715-msd-coil-ballast-resistor-needed.html)
scarceller 02-09-2016 04:49 AM
Here's another thought, with a isolated ground probe, why not just measure the voltage directly across the coil's '-' and '+'? This would show exactly what the voltage is doing across the primary inductor, right?
Seems to me that simple test would tell us exactly what we want to know, how much voltage is at the coil when it first starts to charge, then as it charges the voltage drops till it saturates or gets current limited. I envision this scope trace would start at a voltage around 10-12v (just as the coil turns on) then slope linearly downward toward 0v and at some point it (as it approaches saturation or current limit) it will flatten off likely below 5vdc?
Thoughts?
Sunroof 02-09-2016 06:12 AM
I found a coil that is being sold by ************ that should be satisfactory with my original CDI unit and points system on my 1973.5T 2.4/CIS. They claim it should be a perfect replacement for the older and reliable black Bosch coil. I will remove the MSD blaster and make the switch. If I can make long runs without a shut down, then I will be happy. I will give it a go.
Bob
scarceller 02-09-2016 06:36 AM
Bob,
I think you are referring to this coil?
https://www.************.com/p-1586-cdi-ignition-coil-by-************.aspx
Designed to replace the original bosch coil 901.602.502.00
Bob
Sunroof 02-09-2016 06:54 AM
Yep, that's the one. They claim it is compatible with the three pin CDI unit and has the same internals as the original. They sell a new wiring harness for my model that replaces the wiring from the CDI to the coil and distributor. First I have ever seen one available. My wiring in the 1973.5T is mostly original. With all that heat over the years between the CDI, coil and distributor something has to weaken. We'll see how it goes.
rick-l 02-09-2016 07:39 AM
A differential measurement across the coil will just be battery voltage minus the driver voltage (which is what you have with the lower trace on your scope) so not much info.
To see if the coil starts to saturate you want to see a linear ramp from 0 to 8 Amps or at least as linear as can be with V(1-exp( -Rt/L)) with a very small R (0.6).
This is to see if the DME specific coil core is close to saturation to imply that a CDI coil designed as a transformer would probably saturate. I'm betting it is not.
I wonder how much it would cost (and how big) to wind a coil on a powdered iron toroid with a distributed air gap? We could dream up some marketing hype and sell the monster cable of ignition coils.;)
mysocal911 02-09-2016 08:53 AM
Thoughts?
Based on your previously posted data, you've determined where coil saturation occurs.
Why waste more of your time on this? I'm sure you have better things to do, right?
rick-l 02-09-2016 09:55 AM
Because he doesn't know where (if) the coil core saturation occurs he just knows when the driver starts to current limit.
It current limits either because it reached its design set point or the current suddenly went up because the core won't support the current. Doesn't know which one but I'd bet the former.
scarceller 02-09-2016 10:55 AM
Rick,
Read my post #73 and then look at the video. I think what you'll see in the video is that the coil saturates first then a tad later current limiting kicks in. I'm not 100% certain but that's what I think the scope is showing as I increase the dwell time. See the 3min25sec mark in the video. What do you make of that voltage trace?
timmy2 02-09-2016 11:40 AM
i know someone else building the CDI harness. :)
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/740894-building-sc-mid-year-engine-harnesses-17.html#post8637389
rick-l 02-09-2016 12:20 PM
Originally Posted by scarceller (Post 8991099)
Rick,
Does the scope trace look like this? This is a simulation with an ideal inductor that will not saturate.
http://forums.pelicanparts.com/uploa...1455052764.jpg
scarceller 02-09-2016 12:28 PM
Yes, it looks a lot like that, even the voltage is very close to that. Take a peak at the video.
In your picture, at what point do you consider the coil nearly saturated? I assume right at the knee at the 3.4ms mark? Right before that super sharp rise in current? Correct?
rick-l 02-09-2016 03:05 PM
The ideal inductor in the simulation will never saturate.
From 0 to 3.4 mSec the current ~ linearly rises to 8 amps. The voltage rise over that period is due to the sense resistor and the resistance of the drive transistor.
When the current gets near 8 amps the amplifier in the DME reduces the drive to the base of the Darlington and Vce rises, the slope based on the gain of the differential pair amplifier.
The plateau is the voltage required to maintain di/dt = 0 (Vind = 0) across the copper loss in the coil.
scarceller 02-10-2016 04:17 AM
Rick,
I think I understand, in this simulation the coil never saturates it simply stops charging at 8AMPs. The very sharp upward part of the trace (after the knee) is simply the voltage across the transistor's 'ce' junction as it starts to turn off and limit current.
rick-l 02-10-2016 08:42 AM
Originally Posted by scarceller (Post 8992010)
Rick,
I think that is correct.
The other interesting thing is that given those dwell times you said the DME uses for differing battery voltages, using the inductance and R values in this thread, it looks like the current always bounces off the current limiter. I wonder if they did this to make the design of the coil easier (cheaper)? Fixed dwell would require a lot higher inductance to support the current level over all battery voltages.
That had to be quite a departure from the standard ignition design of the early 80's
http://forums.pelicanparts.com/uploa...1455125405.jpg
EDIT: higher inductance has a lot of other baggage associated with it
EDIT Again: Larger inductance or larger core
scarceller 02-10-2016 09:15 AM
Rick,
No, the stock DME dwell times in the DME don't get high enough to activate the current limit. For me to hit that knee I have to increase the dwell times about 10%.
Basically the stock dwell time is about 3.8ms at 15v and I have to increase it to just above 4.0ms to hit the knee.
Hope that makes sense.
rick-l 02-10-2016 09:39 AM
Where are these numbers from?
Originally Posted by scarceller (Post 8985772)
The 3.2L (and 964) coil dwell times are as follows:
12vdc - 5ms
14vdc - 4ms
16vdc - 3ms
20vdc - 2ms
EDIT with the known coil parameters it should reach 8 Amps at under 3 milli Seconds at 15 Volts.
scarceller 02-10-2016 09:58 AM
Rick,
Those numbers are from bench testing the 964 coils with the 964 BIM firing the coils.
The supply voltage was set as stated and the ms time is right before the knee of the trace occurs. Remember that the voltage is the supply voltage and not the voltage at the coil, it does not account for the voltage drop of the BIM module.
The values are exact amount of time it took to hit the start of the knee. I've mentioned this before, I have never seen a formal BOSCH spec for the coil, that 3.6mH value is something that's been found on the internet I simply would not put all my faith in that coil spec. But those values you listed are taken from real bench test done on the 964 coils with the BIM 124 firing them. I documented how I came up with those values in my video.
rick-l 02-10-2016 10:06 AM
OK
I thought the 2,3,4,5 mSec numbers were from where you disassembled the assembly language code. The DME does have a way to read battery voltage.
scarceller 02-10-2016 10:36 AM
I can calculate the dwell from the dwell map as well. But the dwell map in the DME is not ms based it's crank angle. The processor in the 84-89 DME is not that fast, they did everything based on crank angles (degree of rotation) and crank speed (RPM).
But even checking the dwell time in car shows the DME dwells for 3.8 to 4.0ms or till it runs out of time at hi-RPMs.
The DME has a dwell map with 2 axises: RPM on one axis and Battery Voltage on the other. Then the values in the map are crank angle numbers, it's a flywheel tooth count number that basically says dwell for 'x number of teeth', it's very simple and basic.
Originally Posted by rick-l (Post 8992521)
OK
scarceller 02-10-2016 10:52 AM
I just crunched the numbers from the dwell map.
At 2000RPMs for these given voltages you have these dwell times:
voltage : ms time
5.5v : 9.4ms
7.3v : 9.4ms
9.2v : 8.3ms
11.0v : 6.2ms
12.8v : 4.8ms
14.7v : 4.0ms
15.1v : 2.3ms (this is for any voltage above 15.1v)
Note that at 2000RPMs crank turns 1 rotation in 30ms so we have just 10ms between spark events, this is why the dwell can't be more than 10ms. You see in the above data that they don't ever dwell past 9.4ms or 94% of the available time. They seem to leave 6% of available time for the actual spark event.
Those calcs are very much in line with my bech test results.
rick-l 02-10-2016 01:28 PM
5.5 Volts :eek:
Is that a look up table with RPM on one axis and voltage on the other?
The numbers for 2000 RPM do set the target current between 8 and 10 Amps (except 5 and 7 Volts)
scarceller 02-10-2016 04:01 PM
Rick, I keep coming back to the fact that maybe the specs we have for the coil may not be correct? Could be that coil is higher inductance than we think? Possible?
mysocal911 02-10-2016 07:36 PM
Originally Posted by scarceller (Post 8992512)
Rick,
I can't believe this thread has continued to not arrive at/agree-on the parametric values
for the coil used in the 3.2/964!
Design a simple test circuit using: a 3.2 coil, a 12V - 15A power supply, IGFET, current sense resistor,
a clamp diode, a scope, and a pulse generator. Then using the following equation it's very simple:
L (coil inductance) = V (coil voltage) X T (milliseconds) / I (coil current)
The pulse time (T) is kept short to reduce the voltage effect of the primary resistance.
The same circuit can be used to determine the coil's saturation current.
Or just buy an RC meter, i.e. less $50. Using that you can calculate the secondary's
inductance and the turns ratio.
rick-l 02-10-2016 08:13 PM
It isn't that simple if you want the peak current to go to 15 Amps. For me that is a bunch of capacitors.
I'll buy the inductance at 0 Amps is 3.6 and +/- 10% makes no difference.
mysocal911 02-10-2016 08:24 PM
Good. Issue resolved. Thank you!
scarceller 02-11-2016 05:41 AM
Rick,
I think I crunched the dwell numbers incorrectly, this is what the dwell seems to work out to be from the dwell map at the 2000RPMs row:
voltage : ms time : tooth count
5.5v : 7.2ms :
7.3v : 7.2ms
9.2v : 6.4ms
11.0v : 4.7ms
12.8v : 3.6ms
14.7v : 3.0ms
15.1v : 1.7ms (this is for any voltage above 15.1v)
I calculated incorrectly when converting crank angle to time in ms.
Do those dwell times line up better with your simulation?
rick-l 02-11-2016 07:23 AM
Except for the low voltages those are almost exactly 8 Amps.
mysocal911 02-11-2016 07:27 AM
Originally Posted by scarceller (Post 8993453)
Rick,
5.5v : 7.2ms :
7.3v : 7.2ms
9.2v : 6.4ms
11.0v : 4.7ms
12.8v : 3.6ms
14.7v : 3.0ms
At 6K RPM sparks occurs every 3.3 ms. Given that, what's the dwell time for an adequate
spark energy at about 12 -13 volts applied to the coil (+) terminal?
Assuming that the dwell time is less than a value that results in the 8 amp current limit
(just a little less than 8 amps) of the driver and L = 3.6 mH then:
T = I X L / V = 8 X 3.6 / 12 = 2.4 ms (adequate dwell for adequate energy)
E = 1/2 X L X I ^ 2 = 115 mjoules (30 - 50 mjoules considered minimum)
So why the longer (3.6 ms) dwell time at 2000 RPM?
Assuming L = 3.6 mH, 12 volts, 3.6 ms then:
I = T X V / I = 3.6 X 12 / 3.6 = 12 amps ????
Where's the problem with the parameters, e.g. dwell = 2.4 or 3.6, or L = 3.6 or greater value?
scarceller 02-11-2016 07:41 AM
Dave,
At 6000RPM the dwell map in the DME has the dwell at exactly 2.4ms for 13v
And at 6400 it's at 2.25ms
Just thought I'd share that.
I agree with you that the coil inductance at 3.6mH does seem to line up with the what's in the dwell map. As I said my earlier dwell time calcs where wrong, I incorrectly converted crank angles to dwell in ms.
EDIT: Keep in mind that the voltage in the dwell map is system voltage, at the coil the voltage will be lower. Some voltage is across the darlington and the 0.05ohm sensing resistors. I'm not sure how much voltage is across those components when we near the 8AMPs?
rick-l 02-11-2016 08:20 AM
You have to take into account the resistance of the coil, sense resistor and Vce of the transistor. I aproximated it all at 0.8 Ohms
<table border="1" style="width:100%;">
<tr><td>Voltage</td><td>Dwell</td><td>Time to 8 Amps</td><td>Over/Under</td><td>I at t dwell</td></tr>
<tr><td>5.5</td><td>0.0072</td><td>"-</td><td>"-</td><td>5.4870</td></tr>
<tr><td>7.3</td><td>0.0072</td><td>0.0094</td><td>-0.0022</td><td>7.2827</td></tr>
<tr><td>9.2</td><td>0.0064</td><td>0.0054</td><td>0.0010</td><td>8.7265</td></tr>
<tr><td>11.0</td><td>0.0047</td><td>0.0039</td><td>0.0008</td><td>8.9116</td></tr>
<tr><td>12.8</td><td>0.0036</td><td>0.0031</td><td>0.0005</td><td>8.8107</td></tr>
<tr><td>14.7</td><td>0.0030</td><td>0.0026</td><td>0.0004</td><td>8.9410</td></tr>
<tr><td>15.1</td><td>0.0017</td><td>0.0025</td><td>-0.0008</td><td>5.9384</td></tr>
</table>
mysocal911 02-11-2016 08:30 AM
Right, the calculations were simplifications which basically arrived at the approximate
parameters of the ignition system without actually having to do a simulation or solve
differential equations.
rick-l 02-11-2016 08:51 AM
Through all this discussion we arrived at the fact that the DME coil is designed to operate very tightly at or slightly below 8 Amps based on the dwell times and electronics.
Of course I know you are going to say I knew this all along.
This was most likely taken into account when the coil was designed for this and the 964 application (???).
This goes back to the fact that this is a different coil from the MSD one and what that effects.
rick-l 02-11-2016 09:02 AM
Putting the 8 mH 0.7 ohm coil in the circuit using Sal's numbers at 6000 RPM I get 3.3 Amps which works out to 43 mJ which is below minimum from what I've read.
scarceller 02-11-2016 09:03 AM
Rick, these thought exercises also help us better understand the Motronic system. For me it helps firm up my understanding of the code in the DME. I find these conversations most worth while, and if I ever want to try a different coil (or possibly maybe need to substitute another coil when the stock coils are no longer available) we could do that as well.
scarceller 02-11-2016 09:06 AM
Rick, and you would not have known that the MSD coil is borderline/marginal unless you know exactly what the DME does with dwell times.
So, in conclusion for this thread the answer seems to be: 'The MSD coil is NOT a proper substitute'.
rick-l 02-11-2016 09:49 AM
Looking at that dwell time I'd have to say so. And we haven't taken into account the energy stored (subtracted) in leakage inductance (Xp in the picture). I'm not sure how much core losses (Rc in the picture) affect the total energy delivered. The way the coil is designed as a solenoid to be able to keep the 40 kV apart the leakage might be size able.
Rp effects the time to charge. The energy is stored in Xm.
I don't think the secondary leakage (Xs) and secondary resistance (Rs) affect it much.
wikipedia picture of a model
https://upload.wikimedia.org/wikiped...39/TREQCCT.jpg
mysocal911 02-11-2016 11:56 AM
Right, as was indicated way up-thread, e.g. post #18.
scarceller 02-11-2016 12:11 PM
Since the thread is about a possible aftermarket coil that may/could work properly, how about this one?
http://www.msdperformance.com/Products/Coils/Street/Strip/8253_-_HVC-2_Coil,_6_Series_Ignitions.aspx
It's a 'HVC-2 Coil, 6 Series Ignitions' from MSD, looks very different but here's the specs:
Turns ratio: 100:1
Primary resistance: .16 OHMs
Secondary resistance: 630 OHMs
Inductance: 3.5 mH
Maximum voltage: 44,000 Volts
Peak current: 450 mA
Spark duration: 450 uS
Weight: 3.75 lbs
Not cheap, runs about $200!
thoughts?
rick-l 02-11-2016 01:17 PM
If I was going to spend $200 I would like to know the reasons why so I could weigh the trade offs, not just someones opinion since it seems to work fine. There originally was the question of would it hurt the DME.
Post #18 sounds like a recommendation for it.
Originally Posted by mysocal911 (Post 8985607)
If you read the specs of the MSD Blaster coil on MSD's website, you'll find that it's not
designed exclusively for a CDI application. Furthermore, again using the data from the
link in post #8, you'll find that the typical CDI only type of coil has primary inductance
values less than 1 mh, which is what one would expect since no energy is being stored
in a CDI type of coil.
mysocal911 02-11-2016 04:59 PM
Actually it was post #16:
Originally Posted by mysocal911 (Post 8985235)
"Originally Posted by scarceller View Post
I don't advice you use that MSD coil it could easily result in failed ignition drive circuit as well as a toasty MSD coil."
As indicated in the link of post #8, the MSD Blaster primary inductance is about 4-4.5 mh,
whereas the Bosch coil used in the 911 3.2 has an inductance of about 3.6 mh. So using
the MSD Blaster will not damage the 3.2's DME ECU, but at higher RPM the MSD coil will
produce a weaker spark. So there's really no benefit to using the MSD unless one no longer
has the original black Bosch coil and is forced to use the unreliable silver Bosch coil.
Dave "
That's clearly written!
But if the MSD Blaster is really 4-4.5 mh versus the 3.2 coil at 3.6 mh, then the spark energy
won't be significantly reduced as would be if the inductance were 8 mh. So then the MSD coil
would not really be problematic in a 3.2 application. Again, it's all about the primary inductance,
its series resistance, and the actual dwell time.
