-   -   Carburetor Setup Questions. (http://forums.pelicanparts.com/porsche-911-technical-forum/901886-carburetor-setup-questions.html)
Porschestraße 02-09-2016 04:07 PM
So I just picked up a set of a Weber IDA46's for my 1981 Euro SC. The carbs came with every jet known to man...so my question is; does anyone know what they should be jetted at and set to if I am located in Omaha, NE?
Cheers,
Ben
zedsn 02-09-2016 04:26 PM
Just a question to the carb gurus are 46 too large for a 3.0 euro?
Porschestraße 02-09-2016 08:16 PM
I did my research prior to and got in contact with PMO and Rod, they both agreed that the 46's were just right for the 3.0.
snbush67 02-09-2016 09:14 PM
No, I ran 46's on a 3.0 for a while before I built the motor up to a 3.2. No issues.
snbush67 02-09-2016 09:18 PM
This is how my PMO 46 were set up:
Venturies: 38
Main: 160
Air: 190
Idle: 55
Idle Air: 130
Emul: F11
Porschestraße 02-10-2016 04:04 PM
Venturies: 38
Main: 160
Air: 190
Idle: 55
Idle Air: 130
Emul: F11
Great! Thanks man!
Gordo2 02-10-2016 05:30 PM
Carb Set Up and Tuning
Some in depth info on my tuning efforts with PMO's.
Gordo
http://forums.pelicanparts.com/911-engine-rebuilding-forum/821976-gordos-pmo-carb-tuning.html
Ayles 02-10-2016 06:13 PM
I have 40s on mine, what can you expect by going up to 46?
snbush67 02-10-2016 08:29 PM
Not so much an issue with PMOs, or Weber 46's that have been upgraded by performance oriented.
http://www.performanceoriented.com Will answer all your carb tuning questions, look at tech 1 and tech 2 tabs.
Originally Posted by Steve@Rennsport (Post 4731569)
Just remember, venturi size plays the biggest role in airflow at all throttle openings. This allows you to tailor the carb configuration a bit to each engine's displacement, camshshaft profile and RPM operating range.
The main limitation to using a 46mm Weber (with smaller venturies) on smaller engines in relatively mild tune are the somewhat crude, idle and progression circuits. This is another place where PMO's are FAR superior,..... :) :)
