Self Made.
Porschestraße's Avatar
Carburetor Setup Questions.
So I just picked up a set of a Weber IDA46's for my 1981 Euro SC. The carbs came with every jet known to man...so my question is; does anyone know what they should be jetted at and set to if I am located in Omaha, NE?
Cheers,
Ben
Nothing Else Even Comes Close...well maybe sex.
Old 02-09-2016, 05:07 PM
Just a question to the carb gurus are 46 too large for a 3.0 euro?
Old 02-09-2016, 05:26 PM
Self Made.
I did my research prior to and got in contact with PMO and Rod, they both agreed that the 46's were just right for the 3.0.
Old 02-09-2016, 09:16 PM
No, I ran 46's on a 3.0 for a while before I built the motor up to a 3.2. No issues.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 02-09-2016, 10:14 PM
This is how my PMO 46 were set up:
Venturies: 38
Main: 160
Air: 190
Idle: 55
Idle Air: 130
Emul: F11
Old 02-09-2016, 10:18 PM
Self Made.
Venturies: 38
Main: 160
Air: 190
Idle: 55
Idle Air: 130
Emul: F11
Great! Thanks man!
Old 02-10-2016, 05:04 PM
Gordo2's Avatar
Carb Set Up and Tuning
Some in depth info on my tuning efforts with PMO's.
Gordo
Gordo's PMO Carb Tuning
Don "Gordo" Gordon
'83 911SC Targa
Old 02-10-2016, 06:30 PM
I have 40s on mine, what can you expect by going up to 46?
1982 911 Targa, 3.0L ROW with Webers
Old 02-10-2016, 07:13 PM
Not so much an issue with PMOs, or Weber 46's that have been upgraded by performance oriented.
http://www.performanceoriented.com Will answer all your carb tuning questions, look at tech 1 and tech 2 tabs.
Originally Posted by Steve@Rennsport View Post
Just remember, venturi size plays the biggest role in airflow at all throttle openings. This allows you to tailor the carb configuration a bit to each engine's displacement, camshshaft profile and RPM operating range.
The main limitation to using a 46mm Weber (with smaller venturies) on smaller engines in relatively mild tune are the somewhat crude, idle and progression circuits. This is another place where PMO's are FAR superior,.....
Old 02-10-2016, 09:29 PM
