Which MSD?
Hi. Could anyone advise which MSD ignition would best suit a 2.2 1970 911t? Serial number? Anyone have experience with the outcome of fitting an MSD ignition to a 2.2? Cheers..
Reiver
I used the streetfire on my 930-10 3.0...9.8-1 comp. and it works great, fits in the old CDI spot and with a plug (Timmy2) just plug it in and go. (MSD coil/Clewitt wires/non resistor rotor...napa Echlin eb 407)
At 138 bucks I bought two and have a spare in the smugglers box. However, many like the more 'sparky' 6 units. The streetfire is hotter than the stock CDI but closest to it in specs/volts etc.
De Oppresso Liber Strength and Honor 5th Legion |
Ill second timmy2s plug and play solution. I am using the MSd6 AL digital.
At a minimum you should contact him for wiring info. It makes for a very clean install and no cutting of your factory wires.
1982 911 Targa, 3.0L ROW with Webers |
I'd have the original Bosch box updated to digital by ************
or if you can afford it update the box to the new digital box offered here on Pelican by those Brits who do the fuse boxes.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
ROW '78 911 Targa
His CDI is a 3 pin unit, so the 6 pin adapter plug you guys are using won't work for this application.
I'll be posting a new-in-box MSD 6AL/Blaster(2?) coil, and a new set of magnacore wires that were going in my SC race car before I folded it up very soon in the Parts section...
Gary R. |
Lorraine 83 SC CAB RoW 2003 C4S coupe 07 BMW R1200RT 76 BMW R90S 76 BMW R60/6 |
/ˈpɔrʃə/ PORSH-ə Fan
MSD street fire works great for my 2.7 and I had the 3 pin Permatune originally. It's not exactly bolt on, but awfully close in size and attachment holes. Much better looking than the 6AL sized models.
1984 ROW Carrera Sunroof Coupe Schieferblau 1982 US SC Targa Moosgrun 1977 US 911S Sunroof Coupe - SOLD |
T MSD Streetwise is certainly aggressively priced and it does work well.
My favorite is the Daytona-Sensors CD1 which comes with the coil in the kit I have been using one for 6 years and love it. Very well made and a ton of features. $600 range. It has features like full data logging spark advance etc..
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
ROW '78 911 Targa
Oops, I almost forgot I made a number of these for 3 pin CDI adapters. connects switched power, coil positive and distributor point s from original 3 pin connector to your MSD or other type CDI wiring.
