disassemble fan too here....
So I'm taking apart my fan to powdercoat it.. I've gotten to here.. what's next. Seems stuck.
There at least a couple of ways to do this.
1. You can tap a couple of the small holes adjacent to the fan pulley half. Then use a couple of bolts, and slowly thread them in, alternating from side to side. to drive the fan off. 2. Use a 3 legged gear puller....wrap tape or some other soft stuff around the puller feet to ensure no damage to the fan occurs. These both work well and there are probably other ways..........we'll see who chimes in.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Use 2 or 3 blocks of wood to support the fan housing, so that the alternator hangs down but doesn't contact the table. Then lift it up a few inches and drop it onto the blocks. 2 or 3 times and the alternator will drop right out.
1986 3.2 to 3.4 conversion |
Member 911 Anonymous
on towels :-), key is the housing my be parallel to the ground, gravity is at work here :-)
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
without undoing anything else? (aside from those 3 bolts?)
Functionista
Been using the block method for years. You can use some penetrant as well.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
^^^ +1
ok. ill try it. so fan facing down (second pic, where wires go..up). and lift and drop?
I just did the wood block method and it worked like a charm for me. Give it a try.
'86 Carrera |
I get the alternator out by using the drop/block method.....but i take the fan off first....using the puller.
regards, al
I pull the fan off first with pullers
Then I drop the AC off the blocks
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
I used a bucket with rags in it to catch the alternator once the housing let it go using the 2x4's placed on the rim of the bucket.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow ![]() |
Search "John Walker method"
74 911 Coupe 74 Triumph TR6 97 Jaguar XJ6 |
