vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
One side higher than the other ??
Replace my rear shocks with Bilsteins over the weekend and one side is almost 3/4 inch higher than the other? I removed the higher side shock thinking I put the rubber washer in upside down but it is still the same. What else could cause this? Any chance one shock has a higher spring rate that the other?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 12-09-2002, 01:20 PM
Senior Member
Jdub's Avatar
Did you fully compress the shock prior to installing it to resaturate the seals? This is in the directions, along with advice to store the shocks upright. I wonder about these details though...
Check also the part numbers on each shock at the bottom to be sure they are identical.
Could be the car was being artificially leveled with one bad (old) shock that you have now replaced. I would complete any other susp. bits you plan on tending to and get an align/corner balance performed on the car.
John
'78 Targa in Minerva Blue
Old 12-09-2002, 01:30 PM
Face's Avatar
I was under the impression that your torsion bars affected height if viewed from the front or back? I.e. driver's side tilted lower than passenger side. Maybe a worn torsion bar in cahoots with old shocks and someone adjusting them to incorrectly. Help me out guys, is this correct?...
Todd "Face" Dyer
89' Carrera Silver Edition
F-15E
My Pelican Page
Old 12-09-2002, 02:30 PM
vesnyder's Avatar
It is over an inch off? I assume for this I will have to re-index the torsion bars?
Vance
Old 12-09-2002, 04:47 PM
