86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
A/C switch replacement.
There appears to be a bit of dimensional controversy over the
A/C temperature switch P/N 911-613-121-00 v/s the replacement P/N 911-613-121-01.
This is our original M/Y 1986 factory A/C temperature switch.
And this switch is advertised as the P/N 911-613-121-01
Thanks in advance,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-13-2016, 03:10 PM
83 SC
tkmoore's Avatar
Gerry, there are more detailed threads on modifying the new switch to fit. I used those posts to modify mine last spring. I simply used a bench grinder to slowly and carefully grind down the top of the switch (plastic and metal) until it would fit in the console plate. Be careful to not grind too far--only grind the minimum you need for it to fit. When I did mine, I ground enough that the plastic on top of switch was almost gone and exposing internal components so I wrapped top in electrical tape before installing it to protect the internals. Ultimately, if fit and worked well. Good luck, Tim
Old 03-13-2016, 04:42 PM
Thanks.
1986 911 Targa.
Only in L.A.:
Old 03-14-2016, 08:25 AM
