Dyno dissapointment
Just did chasis dyno on my 79 911 lt wt power at the wheels was 207hp/222 tq. Feeling a little disapointed as the car feels like a monster on the road and is very competitive for DE time trials. At 2550lbs with fuel and driver this thing pulls like a super car and gets it done reliably. Thoughts???
Once a friend of Cliff
rather vague. what have you done to the motor, induction & exhaust? if in OE trim 207 is rather impressive.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Whats your engine setup?
3.4 /906 cams/Weber 46/electromotive xdi/twin spark heads/1.75 headers with 5x14 magnaflows.
Compression?
Could be many things, including tuning/timing. But I agree, not so great results. I would expect 230hp (270rwhp) maybe 5-15 more. What dyno type? Take the numbers with a grain of salt.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 02-26-2016 at 01:24 PM.. |
superflow windyn v3.2
This was 3rd gear which the guy said was my 1 to 1 gear.
Injectors?
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
I'd expect more as well. Can you post a dyno graph with AFR? It may need tuning with the carbs.
1980 911 SC - Black on Red Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html |
I have dual AFR in-dash and fuel is good.
3rd gear is your 1:1? Seems strange to me?
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
911SC 1978-79
5-speed synchronized transaxle Manufactured by Porsche (ZF) Plate-type limited-slip differential available Rod shift Single-plate clutch Gear ratios: 1st gear: 3.18 (11/35) 2nd gear: 1.83 (18/33) 3rd gear: 1.26 (23/29) 4th gear: 1.00 (26/26) 5th gear: 0.82 (28/23) Ring and pinion: 3.88 (8:31) |
If you're pleased with the performance, why worry about the numbers?
Bone stock 1974 911S Targa. 1972 914/4 Race Car |
Great comment, CF!
Seems very low to me. I had a similar 3.4 without the twin plug (but without mufflers too) and I was disappointed when it it pulled 235HP on the chassis dyno (after a few racing seasons). Steve Wong's website has a bunch of dyno sheets on it if you want too see plots from similar engines.
What brand of dyno was it? If it wasn't a Dynojet, but a Mustang, Dyno Dynamics, Dynapack, or worse, some off brand like Land and Sea, the numbers can be all over the place, up or down 20% depending on how the operator sets up the load factors, ramp rate, fudge factors, etc. What is the compression and did you get an AFR curve?
Reiver
Wrong gear.....
De Oppresso Liber Strength and Honor 5th Legion |
I don't reckon injectors are in play with carbs.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft Last edited by car 311; 02-26-2016 at 02:56 PM.. |
Yeah i missed that... Unless he has carbs and injectors!!!
Interesting.
