Dyno dissapointment
Just did chasis dyno on my 79 911 lt wt power at the wheels was 207hp/222 tq. Feeling a little disapointed as the car feels like a monster on the road and is very competitive for DE time trials. At 2550lbs with fuel and driver this thing pulls like a super car and gets it done reliably. Thoughts???
Old 02-26-2016, 12:46 PM
Better in Person
juanbenae's Avatar
rather vague. what have you done to the motor, induction & exhaust? if in OE trim 207 is rather impressive.
Old 02-26-2016, 12:51 PM
Whats your engine setup?
Old 02-26-2016, 12:52 PM
3.4 /906 cams/Weber 46/electromotive xdi/twin spark heads/1.75 headers with 5x14 magnaflows.
Old 02-26-2016, 01:04 PM
gliding_serpent's Avatar
Compression?
Could be many things, including tuning/timing. But I agree, not so great results. I would expect 230hp (270rwhp) maybe 5-15 more.
What dyno type? Take the numbers with a grain of salt.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 02-26-2016, 01:21 PM
superflow windyn v3.2
Old 02-26-2016, 01:23 PM
This was 3rd gear which the guy said was my 1 to 1 gear.
Old 02-26-2016, 01:25 PM
Injectors?
1973 BMW 2002Tii
2016 Ford Focus RS
Old 02-26-2016, 01:26 PM
I'd expect more as well. Can you post a dyno graph with AFR? It may need tuning with the carbs.
1980 911 SC - Black on Red
Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html
Old 02-26-2016, 01:33 PM
I have dual AFR in-dash and fuel is good.
Old 02-26-2016, 01:41 PM
3rd gear is your 1:1? Seems strange to me?
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 02-26-2016, 01:51 PM
911SC 1978-79
5-speed synchronized transaxle
Manufactured by Porsche (ZF)
Plate-type limited-slip differential available
Rod shift
Single-plate clutch
Gear ratios:
1st gear: 3.18 (11/35)
2nd gear: 1.83 (18/33)
3rd gear: 1.26 (23/29)
4th gear: 1.00 (26/26)
5th gear: 0.82 (28/23)
Ring and pinion: 3.88 (8:31)
Old 02-26-2016, 01:55 PM
Charles Freeborn's Avatar
If you're pleased with the performance, why worry about the numbers?
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 02-26-2016, 01:59 PM
Great comment, CF!
Old 02-26-2016, 02:10 PM
Cory M's Avatar
Seems very low to me. I had a similar 3.4 without the twin plug (but without mufflers too) and I was disappointed when it it pulled 235HP on the chassis dyno (after a few racing seasons). Steve Wong's website has a bunch of dyno sheets on it if you want too see plots from similar engines.
Old 02-26-2016, 02:22 PM
Steve W's Avatar
What brand of dyno was it? If it wasn't a Dynojet, but a Mustang, Dyno Dynamics, Dynapack, or worse, some off brand like Land and Sea, the numbers can be all over the place, up or down 20% depending on how the operator sets up the load factors, ramp rate, fudge factors, etc. What is the compression and did you get an AFR curve?
Old 02-26-2016, 02:39 PM
Reiver
Reiver's Avatar
Wrong gear.....
De Oppresso Liber
Strength and Honor 5th Legion
Old 02-26-2016, 02:49 PM
Better in Person
juanbenae's Avatar
Originally Posted by gliding_serpent View Post
Injectors?
I don't reckon injectors are in play with carbs.
Old 02-26-2016, 02:53 PM
Yeah i missed that... Unless he has carbs and injectors!!!
1973 BMW 2002Tii
2016 Ford Focus RS
Old 02-26-2016, 03:07 PM
0396's Avatar
Interesting.
Old 02-26-2016, 03:10 PM
