Front TB cover\tow hooks - leave them off?
Anyone leave the front torsion bar cover\tow hooks off? I bottom out on some driveway approaches. I also have to replace my 28mm dust covers and they are in the way of that.
Todd
'81 SC |
I put sacrificial aftermarket tow hooks on, I'd rather scrape the tow hooks than the torsion bar covers or fuel tank.
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end. http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html |
Call me paranoid, but I felt the same way on the 72.
Greg 86 911 M491 Targa 72 911T Coupe 10 Cayenne GTS |
makes 3 of us, I left them on in fear of bottoming out
Fair enough, I'll leave them be.
Thanks for the confirmation!!! Todd
'81 SC |
Mine are like this and my car is not that low.
![]() I'm nervous about putting on the front air damn as it might just get a jacked up. |
Schleprock
That bent piece happens a lot. You can remove them and hammer back straight by laying the bent piece on a concrete floor and hammering with your sledgehammer. That is, if you are afraid to hammer at them on the car. But since they got bent that way on the car, there's nothing wrong with hammering at them on the car.
Kevin L '86 Carrera "Larry" |
I went through two sets of similar tow hooks as sacrificial parts due to bottoming too often as I had the car lowered to just below euro spec. and needed them just in case I had to be dragged out of a gravel trap at DE.
retired the 911 from the track and have not raised it back to a 'normal' height now that it is a street car again. need to do that...
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
I have the round bar style and had to build up the bottoms they were ground flat. But they grind almost every time i leave my driveway and save the air dam and everything else. The only time thats hit the ground is when i went in a ditch.
82 SC , 72 914 |
Mine have been off for years...no ill effect other than breaking off a grease zerk once.
1986 3.2 Carrera |
Round style here - built them up and painted them nice last fall. Touch down for the first time since yesterday.
I should have used hard-face.
1981 911 SC 2013 Mini Cooper JCW 2017 GMC K1500 |
I ground the hook portion off mine so I could keep the covers as protection.
Mat P 1988 911 Carrera |
If you don't want to swing a hammer near your ride (or don't have clearance to do so), a large pair of channel lock pliers and / or a large adjustable wrench will help you safely tweak those bent hooks back in-situ.
Straight shooter
Rennline hooks. A little set of wheels would be funny though.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
