Replacing intake manifold gaskets. Quick help needed!
Does this look right to you all?
I found phenolic spacers between the two old gaskets, but when I replaced them with new Victor Reintz, it looks like the inner diameter is quite a bit more narrow than the spacer and even the manifold.
Old 03-08-2016, 07:22 AM
No. You want the gaskets to be the same as the port diameter. In a perfect world, the intake runner, spacers, gaskets and ports would all be the same diameter and all would be concentric.
Anything else and you reduce the airflow and thus, the power produced.
JR
Old 03-08-2016, 07:27 AM
Would it be OK to cut them to fit? The catalog says these are the right gaskets, but clearly they are not.
Old 03-08-2016, 07:36 AM
That's one option. You might find it difficult to get a nice, smooth round cut. If that were my engine, I'd buy another set of gaskets. I don't care what the catalog says, those aren't right.
JR
Old 03-08-2016, 07:39 AM
Thanks. Looking at the options, I see I need the 38mm diameter ones that come on the 911S -- except I don't have an S. Maybe I just have S heads. One more mystery thanks to the previous owner.
1966 Granite Green 911
Old 03-08-2016, 08:15 AM
Might want to look a little deeper to see exactly what you have... If you have S heads, maybe other stuff got changed, too.
JR
Old 03-08-2016, 08:17 AM
T77911S's Avatar
measure the port diameter
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-10-2016, 05:38 AM
Stick a rag down the port and with the gasket sitting on the spacer, use a sharp pocket knife to carefully carve out the center. Mechanics 101.
206 637 4071
Old 03-10-2016, 06:04 AM
Hi
Targa Me's Avatar
Thanks for the idea, John.
Sometimes the painfully obvious, is not so obvious... to me anyways.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 03-10-2016, 08:46 AM
Pull the gasket and mark the material with the insulator to the required diameter and use a box cutter with a razer blade to make the larger diameter circle. Won't take a chance of getting any foreign object in the intakes that way.
Old 03-10-2016, 02:37 PM
