Idle position switch question - failure result?
Idle position switch question, sorry for the confusion. Idle position switch fails continuity test. Continuity remains from idle through full throttle. Bentley 240-20 electronic test says continuity should only be upon idle.
Would this cause break up/backfire under load? Thanks, Dave Last edited by 198491132; 03-17-2016 at 01:22 PM.. Reason: New find |
