who's running an AFR gauge?
thinking I'll run an AFR gauge with the new engine. this one:
mostly because it's a decent quality and won't look too out-of-place in a '67. I might do two, one for each bank. or maybe I can figure out how to have two senders and switch the input to one gauge. anyone had any experience with an AFR gauge? thanks, Don. |
A search will turn up several threads on this topic.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
River Rat
Innovate
I have the Innovate and have been very happy ... Key to a good install is making sure grounds are adequate.
Regards, Dave
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs. |
Schleprock
I have that exact one on the '79 (3.0L w/Weber 46s) and it works great. Use it to dial in my A/F since I had to re-jet due to the carbs being tuned for 110 octane. However i'd recommend the digital version for at-a-glance visibility at speed. Still, the analog one works well.
I vaguely recall AEM makes a harness adapter that you can buy to join two O2 signals? Check out their website to confirm. They recommend these not be used for continual operation at very high EGT temps. So once mine's dialed in, i'll pull the wideband O2 out and plug the exhaust. Wideband O2 sensors are fairly expensive so I see no reason to kill it running WOT on the track all the time. I'll just put it back in on occasion for a periodic check.
Kevin L '86 Carrera "Larry" |
beancounter
I also run an innovate system.
LC-1 wideband AFR with permanently mounted gauge and a DL-32 for datalogging of AFR, RPM, MAP, acceleration/braking g's, and cylinder head temp. ![]() ![]() Interfaces with my UMPC to form a "digital dashboard"
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
grateful user
![]() I like the inovate. I have an adjustable wur so it is a must. Makes for easy tuning to.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
abit off center
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
I really like the gauge pod in the ashtray hole. I'll do that. also the voltmeter, I've missed having one since the 914.
I had a custom gage built for the clock that interfaces with an LC-1. Have two O2 sensors (L&R) and a switch that can toggle between the two.
'72 911T '73 MGB (sold) '71 Alfa GTV (sold) |
Ive run a wideband 02 sensor in my cars for years for tuning . I cant imagine going back to guessing AFRs! I want to recommend an analog gauge . If you are trying to tune injection or carbs digitally
with poor drivability during quick throttle motion, it is very hard to tell what is happening when all the digital numbers are changing so rapidly. With the analog gauge the needle sweep tells you a very accurate story. |
I had the gage done by BigMark Design (bigmarkdesign@aol.com). I sent him my core and he provided the rest. I think it was about $200. Actually, I used an LC-1 that allows some programming to get the analog gage calibrated. I bought a vintage-looking switch from Radioshack and mounted it in a pre-existing hole in the dash under the speedo. I think this hole was there for a fog light switch.
It really has been a BIG help when trying to dial-in the Webers. Hope that helps.
I have been using a good AFR gauge on my 1973 2.7L MFI engine for more than a year. Did lots of research before I bought. In my opinion the Innovate is a 5+ year old design that is expensive and difficult to hook up. I went in a different direction and have been very happy.
My choice was the Daytona-Sensors WEGO IV. The major advantage is that it is a small all in one unit that has 2 hours of data logging. You download the data and look at the charts using the supplied software. Or you can download in an Excel spreadsheet and study the numbers on the spread sheet. In addition to AFR, you hook it up to the tach wire on the 911 so you can see RPM, AFR, and mine has a MAP sensor so I can see manifold vacuum. DATA LOGGING IS VERY IMPORTANT! I can't say enough about this. You do a good run, and study the data and make adjustments. Looking at the gauge while you drive is not the way to go. Trust me. You can get data logging on the Innovate and others, but it is usually a very expensive add-on. ![]() This is the unit and the sensor. Kit comes complete with cable, bung, software and full instructions. They also make a double unit that looks like this: ![]() This comes with 2 sensors and 2 readouts and data logging for both. Programming and downloading are done with a USB cable to a laptop. The single unit is a little over $400.00 USD and is sold by our hosts. I would seriously look at this unit. I am very happy with it. Very reliable, easy to install and data logging is a must.\ Here is the full kit contents.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
By the way it is made in the USA in Daytona Florida. I noticed the USB cable in the kit has a made in China on the packaging. This is a USA made unit. check out the website Daytona Sensors LLC - Engine Controls and Instrumentation Systems for Automotive and Motorcycle Applications for more information and you can even download the software if you want to check it out.
New User
Any info Cheers -Kav |
Yes, used a two position switch between two LC-1s and the gage. They shared a common ground snd the signal was switched.
Location: behind the redwood curtain, (humboldt county) california
Many points to consider,,
Ergonomics, (how easy is it to see, when you are testing - higher is better)
Compatibility, can i run it full time from the canbus on the megasquirt?? The MS has good data logging capability but will it run a gauge full time also?? How helpfull is dual sensor input/cost??? It seems that an analog gauge might be more user friendly than rapidly changing digital display, But?? Experience??? obviously, data logging makes this question moot. Cost to add to a MS EFI?? Lastly, appearance, does it look OE, like the slick clock replacement with volts/O2? Obviously, I'm not asking my wife, who subordinates function, ergonomics, cost, durability, repairability, compatibility and everything else to "How it looks" - sorry, slipped off my meds there for a moment. :-) chris |
New User
Great thanks! I thinking of running 2 AEM 30-0310 wideband controllers, any thoughts on that? I've heard the LC-1 connectors can be temperamental? Cheers -Kav. |
This issue was discussed here earlier this year: two sensors one AF gauge Sherwood |
I have one from a Pelican member who installed the gauge in the tachomemter, replacing the boost gauge. I have a boost gauge in the clock position anyway. I think it was called "In your Face". It's a PLX gauge, I really like it
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel |
