Targa_PB_78_SC
mike sampsel's Avatar
78 SC rough running hard start
I removed my air boot and hoses etc. to get a look at the holy triangle.
Saw fresh oil ... plan to correct sometime ...
After return of boot and hoses the car was hard to start and dies at idle.
Any guess as what might be the cause before I remove boot to
determine where I went wrong.
Old 03-19-2016, 05:52 AM
pete3799's Avatar
I would double check that you got the hoses reconnected properly. Did one of the hoses develop a crack (leak) when you removed them?
Sounds like a vacuum leak is causing the problem.
Pete
79 911SC RoW
Old 03-19-2016, 06:21 AM
The black boot across the top has developed a crack along the clamp line.
Bruce
Old 03-19-2016, 07:55 AM
Targa_PB_78_SC
Bruce
I'll be checking (the boot is fairly new 5-6 year old or so).
I wonder if the metal elbow into the boot were backwards what this might do? The line which goes to the air regulator/warm up regulator.
Old 03-19-2016, 08:59 AM
