joe payne's Avatar
Lets play, whats your tire pressure!
As a rule of thumb I usually set my tire pressures at 29 fronts and 34 rears for strret and canyon driving. my cars is corner balanced and feels neutral most of the time. The front of the car is 1,025 lbs and the rear is 1,613 lbs.
I just swapped out my worn Kuhmo Ecsta MX tires to Dunlop Direzza V2's and I'm looking forward to a possible performance improvement. Also, I understand that tire pressures may need to be adjusted based on driving style.
If anyone has a good tire pressure improvment that could be made, I would like to hear what you suggest.
jtp911
Old 06-10-2015, 10:14 AM
tobluforu's Avatar
Old 06-10-2015, 10:55 AM
Oh Haha's Avatar
30 f
34 r
Pacific Blue
Wayne
Old 06-10-2015, 11:01 AM
Len 911's Avatar
Yep there not flat pressure... Never really checked them ..I guess I better.
Old 06-10-2015, 11:51 AM
Air Cooled
Craig_D's Avatar
I run Dunlop Direzzas too, and really like them.
30 f
33 r
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 06-10-2015, 11:57 AM
Eva
911SauCy's Avatar
29f/32r
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 06-10-2015, 12:04 PM
Still here
pmax's Avatar
I'll play , I'll play !
P0's
30f/40r
Old 06-10-2015, 12:08 PM
MARISOL78sc's Avatar
29/32 RE11's
Old 06-10-2015, 12:11 PM
Brown Out
RRWood's Avatar
36/40, Dunlop 8000, 205/55/16, 245/45/16
RR Wood
1960 Corvette
1980 911SC 3.6
1998 Chevrolet S10 Sportside LS1
Old 06-10-2015, 12:32 PM
P6000's 29f 34r
Just as a note - skid pad instructors, this past weekend, said car was nicely setup. Just sayin' since I have no other frame of reference.
BTW, how did you like you Kuomos?
Wayne
1980 911 SC
1960 MGA 1600
Old 06-10-2015, 12:33 PM
gearhead
Another 29/32. Michelin Pilot Sport Exaltos.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-10-2015, 12:34 PM
Vintage Motorsport
RichardNew's Avatar
Make sure you use the same gauge all the time. Tire gauges are wildly inaccurate. That's no be deal you stick to the same one all the time. More than you need to know about the gauges.
Richard Newton
Old 06-10-2015, 01:09 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Tire pressures.
I top off all four @ about 32F & 38R.
Drive the care home, park it overnight.
then bleed the air down to:
29F & 36R.
28F & 33R might reduce center wear......
The tires are Pirelli:
PZER0P205/55ZR16 F
PZERO225/50ZR16 R
Street use only.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 06-10-2015, 01:13 PM
Member 911 Anonymous
DRACO A5OG's Avatar
So PAG spec is 29/36. Are we saying it depends on brand/type of tires to determine pressure?
I know on the track, I lower it but for street I go to recommend PAG spec.
My MBZ wrench told me that MBZ spec is way too low so he filled it to 40 lbs, well a couple months later tires were bald in the center. WTF???
'85 Carrera Targa
PCA/POC
Old 06-10-2015, 01:23 PM
joe payne's Avatar
The Kuhmo's were a great tire. They lasted about 10,000 miles of aggressive and street miles.
They were worn down to the wear bars. Flat across wear mostly for the rears and perfect front wear showing just enough negative camber. Some complain that they have soft sidewalls but they worked for me and proved what a set of sticky tires can do for performance.
I thought I would see quite a difference in pressures from everyone. Some 32 psi rear guys and some up to 40 psi rear guys and some between.
jtp911
Old 06-10-2015, 01:48 PM
joe payne's Avatar
One more thing, I think the construction/type and make of the tire may affect what air pressure is best, so I was not sure with the Dunlops. Craig D, Glad you like them! Your car looks similar to mine too.
jtp911
Old 06-10-2015, 01:53 PM
29/34 Nitrogen, Falken ZIEX (ZE921)
70 911T Sold 81 911SC Coupe
84 Mustang Turbo GT
66 Galaxy 500 Ragtop (my Mother bought it new)
88 Thunderbird Turbo Coupe
69 Torino Cobra (R) Code
Old 06-10-2015, 02:15 PM
BFT3.2's Avatar
RE-11's 29/34 cold for street, 36 hot all corners for track.
______________
'88 911 Coupe
'98 Spec Boxster
'85 380SL Benz -Euro
Old 06-10-2015, 02:36 PM
Functionista
manbridge 74's Avatar
Been eperimenting over the years but now at 28/30 in a 2250lb 74.
Old 06-10-2015, 07:23 PM
Undocumented User
McLaren-TAG's Avatar
I'm fortunate enough to have a handful of SCCA national level guys in my region and over the years I've picked up a lot on their techniques. One of these guys now has an 85 and he told me a bit back that these cars really prefer a 3 lbs difference front to rear. Interesting that a lot of the posts here reflect that 3 lbs difference.
I have Direzzas Z2 and I run primarily run 29/32 on spring day conditions but tire pressure depends on many factors and has to go up an down based on what you need for the circuit and the weather.
Old 06-11-2015, 04:27 AM
