current weber settings
30mm Venturis 125 main jets 180 air corrections f26 emulsion 70 idle metering jets Heres the problem at the above configutaiton the car runs and accelerates great but wont idle for crap. So I put in 55 idle jets and it idels great but farts and pops and accelerates for crap. Question what can I change to have the best of both worlds. carbs have been synchronized and this is a 2.0 litre Dean |
2.0 what? stock venturi for a T is 27mm. 110 mains and 55 idles along with proper adjustment should work. if it's been hot rodded, or if it's an S, it will need different jetting. you may have to clean or replace the sparkplugs more than once, if they get black while you work out the bugs. any tuning needs to start with clean plugs.
[This message has been edited by john walker's workshop (edited 10-10-2001).] |
