Q2: Yes you will need to remove the guard plate. Actually replacing the hoses isn't all that hard. A bit tedious and dirty for sure but all in all it's pretty straightforward. One thing I'd recommend though is tie some to cord to the ones that go to the front condenser when you pull them out to use to help feed the new ones back in. |
Filter the liquid through a white coffee filter and inspect for metal particles (5x loop works). New barrier hoses, drier, o-rings, low high pressure switch as a minimum. Hope some of that red hue is Dr. Pep Cherry! Good thread so far! |
After years of threatened litigation he finally sent me a free bottle of Ester oil to smooth things over. I paid shipping. All's been good since. |
I ordered a full hose kit from Griffith. I probably won't get to the hoses this weekend but should be able to post more over the weekend on installation of the new front condenser, prep and reassembly of the EVAP and blower box, TXV and copper guide tube and hopefully reinstall the rear condenser and rear deck lid. I removed the rear deck to repair or replace the third brake light. I'm piggybacking on Autoban's thread on modifying his third brake light - found here - http://forums.pelicanparts.com/porsche-911-technical-forum/906889-86-cab-custom-third-brake-light-flasher.html |
http://www.digitalbookworld.com/wp-c..._540590621.jpg |
You could have fiddled and saved a few bucks with the cost of time. However, GT stuff does not break. There is comfort in that. I think the suction side hose is a little longer so you can get the AC compressor well out of the way for valve adjustments. |
This thread just keeps getting better and better.
Ronnie's.930 - I have some brand new really nice AC stuff if you have any interest in bartering ?:D
Well, Griffith sent my candy overnight - thanks! Decided to spend just a couple of hours organizing for the weekend. Here's some pics you might find interesting. Hoses look really nice - absolute top quality stuff. http://forums.pelicanparts.com/uploa...1458781335.jpg Nice packaging, needed accessories, and nice documented instructions. http://forums.pelicanparts.com/uploa...1458781389.jpg New front condenser blower and motor and cleaned, prepped blower housings http://forums.pelicanparts.com/uploa...1458781466.jpg http://forums.pelicanparts.com/uploa...1458781627.jpg New front condenser - really nice. http://forums.pelicanparts.com/uploa...1458781539.jpg http://forums.pelicanparts.com/uploa...1458781604.jpg New drier and Thermal Expansion Valve - brushed down the pigtail clip for good contact. Q: Still need to find out where to source the tar paper covering - anyone ? http://forums.pelicanparts.com/uploa...1458781693.jpg Evap cleaned and flushed: ready for reassembly http://forums.pelicanparts.com/uploa...1458781792.jpg A peek http://forums.pelicanparts.com/uploa...1458781852.jpg |
Speechless.
Did you clean up the blower cage and motor? Lovely! |
Ramp... u run into any problems with the hose, you're welcome to call me. 786-449-4488. Am passing on the PelicanBro "call-me" --- I've benefited from that... thank you Ron on the relay. Not to brag but I've done hose a few times... not on same 911 if that means anything. I have Grif's system in my Targa. No one does better install instructions than CG. Equip is primo. And tech support lasts forever! No AC company supports their product better. |
CG does make top shelf parts. His instructions are even better. I wish I had a complete repair manual for my 911 written by Griffiths. It would be 30 volumes and anyone could rebuild any part of the car.
I have had my Griffiths system for right at 10 years. It is the best investment in my 911 I have made in the 20 years I have owned it. I can drive my car on 100+ degree days in comfort. You will love the final result. Swapping the hoses is dirty work but not very difficult. Just follow his instructions step by step. Good luck and keep posting! |
Last week took care of some small things -clean all grounds and battery terminals, started cutting a baffle for the Evap housing, put the front condenser blower with new motor/fan assembly back together, cleaned up the speed control and area, removed dryer, and took the clutch off the compressor.
Q: Take a look at the compressor - It was pretty clean and I didn't see and signs of leaking so I may juts put it back on - Thoughts ? Today I dove into the hoses- not too bad so far but it's a dirty job- the lift is great but in the way a bit to get at the underside hoses Started with the front condenser hoses and put up the new front condenser from Griffiths. EDIT: I attached a bunch of Pics but they're not showing ?? http://forums.pelicanparts.com/uploa...1459637848.jpg http://forums.pelicanparts.com/uploa...1459637864.jpg http://forums.pelicanparts.com/uploa...1459637889.jpg http://forums.pelicanparts.com/uploa...1459637906.jpg http://forums.pelicanparts.com/uploa...1459637937.jpg http://forums.pelicanparts.com/uploa...1459637974.jpg http://forums.pelicanparts.com/uploa...1459637987.jpg |
I had a problem uploading pics earlier. Think something is wrong with the server.
How long should it take a knowledgeable porsche tech to replace all hoses in my 1974 with front and rear condensers?
The convenience of a lift makes all the difference in the world for this kind of job. I'd say someone who knows what they're doing and doesn't run into something like a stuck hose fitting that wastes a bunch of time -- couple of hours to get them off and a couple of hours to get them on.
A lift does not save you that much time. The LH front and RH rear tires need to come off. Dirt falling down that has accumulated behind the hoses is the annoyance, so baseball cap, safety glasses, and a shop vac are needed. For a DIY, floor jack and 4 jack stands get you where you have to go. It's a weekend job. |
I just completed the Kuehl AC upgrade. Here's what I learned. I worked with the car on 4 good jackstands in a 1 car garage. I had 30" between the driver's side and the wall, 18" on the passanger side, 18" in front and if the garage door was closed 18" in the rear. I worked slow and methodical.
I replaced the evap, drier all hoses, front condenser, added the Duel Kuehl rear wheeelwell condensers and a new compressor in approx 24 hrs total time over 2 months. The main pieces of advice are: 1 - READ the manual Charlie supplies and read it again. It is exact. 2 - Try to fish the new lines behind the windshield washer tank or if you remove it empty it! Trying to reinstall a full tank on my M491 car was not fun. 3 - Call or email Charlie with any question and he will promptly answer. I think he takes a little longer to answer smoke signals. 4 - Yes, it can be dirty, very dirty. Wear safety glasses 5 - Did I mention reading the manual? Every thing becomes self explanitory as you go. One step at a time. |
Maybe I read the question too narrowly. I read it as asking a shop just to R&R hoses and nothing more. I estimated 4 hours of labor to do that. Maybe that's optimistic. A lift certainly isn't required.
For a DIYer that would be completely different and depends on what needs to be done in the process. I have a pair of cutters that have a wide mouth and they use a replaceable razor blade. They are super handy for this kind of job. (Note my system was bone dry.) I used those to make strategic cuts in a few places of the old hose. Basically I made cuts at the 4 corners of the tub and a couple of others places. Had he old hoses off in no time. Installing the new hoses was not bad either -- at least to me it wasn't the big deal some people have made it out to be. I have done far worse jobs in my Porsche ownership (replacing the headliner and replacing torsion bars comes to mind). I probably spent the most time on installing the two wheel well condensers and the evaporator. I did the condensers separately while I had the engine out of the car so it's hard to say how long I spent there. Like others said though, reading the material ahead helps. Overall, like Charlie said it's a good weekend project barring any unforeseen setbacks. I did have a setback with my old decklid condenser. Sourced a new one that blew a pinhole leak the first time it was pressurized. Had to wait on it's replacement. Had one flare fitting that really put up a fight. You can burn daylight on some of the dumbest little things. I repainted the protective cage after I pulled the old nose condenser. Some people don't get distracted by that kind of stuff but I do. There's an extra 30 minutes right there. |
Hope all is well with your project! We've had an unfortunate cold snap with a return of snow and road salt in NE Ohio.
Here's what's done. I have some pics now but more in a day or so when my PC is back up. 1. All new Griffiths hoses are in. Took about 6-7 hours taking my time. Probably took a pound of gravel off the car. I will still need to adjust them a bit once all components are back in so I can test fit. The hoses up over the front washer fluid canister in the driver wheel well are a pain - I had to remove the canister (easy) and put it back (hard). The line from the front drier under the driver-side back to the rear condenser is not too bad but feeding it through to the engine compartment from underneath was hard until we "lubed" the line. 2. New Khuel Front Condenser installed. 3. Rear Condenser flushed, cleaned and reinstalled. 4. New Khuel drier installed. 5. Evap flushed and cleaned. New Thermo Expansion Valve installed. 6. Evap blower baffle made per other Pelican posts. 7. Front condenser blower motor replaced and reassembled. New foam padding installed around base of front blower. Cleaned the blower area and battery grounds while in that area. 8. Bought a media blaster and cleaned off the steering rack skid plate, front condenser cage and front skid bar - ready for paint this weekend. 9. Compressor media blasted and cleaned. Clutch removed, inspected and cleaned up. The compressor and seals "seem" to be intact in good condition. no oil seepage showing. Still haven't decided on replacing it or keeping it. I used 2 cans (16oz) of Ester 100 Oil to "run through" the compressor; I know you can't flush. I added 4oz at a time to the compressor and then used a nut driver/drill to crank the compressor over until the oil was expelled. Repeat until the oil was "relatively" clean. I may do more but ran out of oil. 10. Made a new thermostat guide tube from copper tubing sourced at hobby shop for $1.59 (plus $7.00 for a flaring tool at HF). Still need to be installed. Q: The guide tube should be 1/2 way through the Evap - Correct ? http://forums.pelicanparts.com/uploa...1460419286.jpg http://forums.pelicanparts.com/uploa...1460419310.jpg http://forums.pelicanparts.com/uploa...1460419333.jpg http://forums.pelicanparts.com/uploa...1460419349.jpg http://forums.pelicanparts.com/uploa...1460419384.jpg http://forums.pelicanparts.com/uploa...1460419454.jpg http://forums.pelicanparts.com/uploa...1460419475.jpg http://forums.pelicanparts.com/uploa...1460419496.jpg http://forums.pelicanparts.com/uploa...1460419510.jpg |
Great progress! Thanks again for sharing your work. This thread will be so useful when I eventually address my AC.
(With compressor out Ramp, you might want to look at / replace shaft seal (if it has one.) A few bucks for the seal.) |
You have gone the mile so why ponder the yard it will take to disassemble the compressor, inspect its pistons, bores, wobble plate and reed gaskets. If all looks good drop in a seal kit.
New Question:
There seems to be a baffle for the front condenser blower - see below. I don't have one and don't believe I need one. Thoughts ? A/C Condenser Baffle Plate Part #: 911-501-581-01-GRV-OEM http://forums.pelicanparts.com/uploa...1460568965.jpg |
mthomas58 - Thanks for the link !
It would appear that my 'baffle' is built onto the tub. From the parts diagram it looks like a separate component. http://forums.pelicanparts.com/uploa...1460575304.jpg |
Compressor Work
OK, need some advice on this part. I took the compressor mostly apart yesterday. I don't see any rough spots or flakes of metal. The oil was a bit dirty but I expected that since the oil drained from the rest of the system was close to black.
What am I looking for or at ?? The pistons go up and down smoothly with slight finger pressure. I'm thinking, clean, replace the o-rings and seal and put her back together. Thoughts ? http://forums.pelicanparts.com/uploa...1460899416.jpg http://forums.pelicanparts.com/uploa...1460899429.jpg http://forums.pelicanparts.com/uploa...1460899439.jpg http://forums.pelicanparts.com/uploa...1460899450.jpg http://forums.pelicanparts.com/uploa...1460899459.jpg http://forums.pelicanparts.com/uploa...1460899476.jpg Awesome Hatchet Porterhouse that evening - the hatchet bone was 20" http://forums.pelicanparts.com/uploa...1460899484.jpg |
You need to inspect:
1) Pistons for scratches and worn moly coating (grey black coating). 2) Cylinder Bores for scratches and 'chatter' marks. 3) Wobble plate (round aluminum disc on shaft) for grooves cut by piston half bearings. 4) Shaft for rust or pitting wearing shaft seal rides. 5) Reed plate assemblies (aluminum plates, steel reeds, polymer (plastic like) coating 6) Thrust and needle bearings. Wipe off the shaft. Hold it firmly with fingers of one hand. Gently tap the back section or case half with plastic mallet against the mount boss to separate the case halves; keeping the shaft with the pistons in the front section. Inspect and provide pictures. |
| All times are GMT -8. The time now is 12:16 PM. |
