Administrator
Jack Olsen's Avatar
Building a better Black Beauty #3: Reinforcing the Chassis
These pictures aren't comprehensive, and some of the work was only partially done when I took them. But they show the new tub for my car getting the following:
Deleting both battery boxes for oil cooler air flow.
Sealing up holes from old dealer-installed AC. New version of car will still have the 37-degree AC engineered by TRE.
Reinforcements for front, through-the-body swaybars.
Welded in mounts for full cage.
Power-assist brake setup from post-77 models.
Welded-in reinforcements for real coil-overs as well as reinforcement of rear crossmember.
Here are pictures, in no particular order.
Old 12-12-2002, 12:23 PM
Administrator
Jack Olsen's Avatar
Old 12-12-2002, 12:24 PM
racemor's Avatar
Looks like good work Jack. How are you finishing the interior, trunk, etc? Will you completely disassemble everything after the mods are done and spray the complete car, interior and exterior?
Tom
'18 Carrera T
R #368, S #692
North Carolina
Old 12-12-2002, 12:41 PM
Non Compos Mentis
Impressive!
Excuse me while I wipe the drool off my keyboard.
Old 12-12-2002, 12:45 PM
Bill Verburg's Avatar
Very nice Jack!
Bill Verburg
Old 12-12-2002, 12:49 PM
Eric Mckenna's Avatar
Jack,
That is GREAT! thans for all the nice up close pic's of the transformation.. SUPER.. I love the rear tower supports.. you are not going to weld the rol bar in? .. is it better to bolt in ot weld in? just wondering..
Thanks again Jack, BTW I was wondering if you still had any of the wheels for sale?
Eric Mckenna
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 12-12-2002, 12:53 PM
makaio's Avatar
Thumbs up
SWEEEEEEEEEEEEEET!
It's going to be awesome.
Old 12-12-2002, 12:54 PM
Randy Webb's Avatar
I thought the early cars were already set up for this? Isn't yours a 1973? Or is it set up for them, but still needs reinforcement?
Old 12-12-2002, 04:49 PM
Jack,
On the rear engine compartment photo, the welding they did in the corners. Did they install a plate or just weld the seam?
Any closeup photos.
Thanks for the info.
Tinker
Old 12-12-2002, 05:38 PM
Administrator
Jack Olsen's Avatar
This new tub is a 72, and came with a factory swaybar, which goes through the body. However, the factory provided a fairly small swaybar, designed for tires that were skinny, with compounds that couldn't hold a candle to even today's average street tires.
So, to prevent the three bolts from tearing loose under the stress of modern bars and tires, you can reinforce the area where the bar mounts, and then drill out the hole to allow for a bigger front bar. The stock hole will accommodate the 22mm bar I'm currently putting in, but we drilled it wider as a preemptive measure.
Tinker, I think it's just a beefier weld, but I'll take a look tomorrow.
Old 12-12-2002, 05:39 PM
I'm jealous! I'd love to take on a project like this, and have some ideas rolling around in my head,but I chose to restore a VW crew cab this winter. Maybe next year.
I also wanted to use a '72, because I like the external oil filler.
Old 12-12-2002, 06:40 PM
makaio's Avatar
Gesh Kevin, you could have at least candy coated it a little .
Old 12-12-2002, 08:07 PM
beepbeep's Avatar
Looks really decent!
Now all you need is turbocharged engine....repeat after me:
boost is good
boost is good
boost is good
all that 3.6 crapola has less than old 930 engine produces stock
Hmm...i wonder what difference tricked out turbo engine would do with that light weight
Yeah baby yeah!
Thank you for your time,
Old 12-12-2002, 08:18 PM
Thumbs up
Another top notch project. What about painting her Silver?
Old 12-12-2002, 08:51 PM
nostatic's Avatar
at least it got recycled into a sassy and useful dumpster.
oh...you mean the parts are on the *inside*. Oh Venkman...I'm sorry.
We've been going about this all wrong. This Mr. Stay-Puft is okay. He's a sailor, he's in New York. We get this guy laid, we won't have any trouble
Old 12-12-2002, 08:58 PM
Buy them, sell them
Adam's Avatar
I just blew Vanilla Coke out my nose!
It's looking good, Jack. Are you getting new 17" Fuchs for the RSR bodywork?
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 12-12-2002, 11:32 PM
dickster's Avatar
fantastic jack
Rich
'86 coupe
"there you are"
Old 12-13-2002, 12:31 AM
Administrator
Jack Olsen's Avatar
Yup. If you're going to have that much room, you might as well fill it up.
Old 12-13-2002, 12:48 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Looks like it's coming along. It looks like it won't be too long til you're back out on the track.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 12-13-2002, 05:23 AM
rs911t's Avatar
Looks good! A question: what's the "proper" way to mount harnesses with that type of rollbar? Will you add a crossbar or simply attach to the rear bulkhead and run the belts thru the seat openings?
Greg
Old 12-13-2002, 07:40 AM
