Counterclockwise?
School me on aftermarket ducktails pls.
I'm looking at an aftermarket ducktail and I'm concerned on the fit. The gaps on the bumper end and sides are okay, but they are tight and not flush. It is consistent so I guess I could just mount it and live with it.
The edge at the window sits about 1/2" high in the center and is bottoming out at the corners. (gap under the middle)
The grill is about 1/2" too big (top to bottom) for the hole.
Is this just normal growing pains for putting on a ducktail?
My body shop guys says he can fix it, but it will take a lot of cutting, adding glass etc.
Your thoughts fellow birds?
Rod
Rod
1986 Carrera
2001 996TT
Old 03-28-2016, 09:26 AM
any idea who made it? mine has a smaller engine grill opening, i had to add a lot of washers at the hinges to raise the corners up to bring it more flush with body.
Old 03-28-2016, 10:01 AM
Counterclockwise?
Unknown manufacturer. Problem is it sits too high.
Rod
1986 Carrera
2001 996TT
Old 03-28-2016, 10:41 AM
Counterclockwise?
And the opening is too small for the grill.
Rod
1986 Carrera
2001 996TT
Old 03-28-2016, 10:47 AM
Counterclockwise?
Rod
1986 Carrera
2001 996TT
Old 03-28-2016, 10:59 AM
Registered Minimalist
75 911s's Avatar
I'd opt for a different tail. Looks like a cheap poor quality pop.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 03-28-2016, 11:12 AM
Rod
I got mine from www.Rennspd.Com and it fit perfect.
Old 03-28-2016, 11:16 AM
<insert witty title here>
Christien's Avatar
I got mine from MA Shaw and it was almost 100% perfect right out of the box. Close enough that it wasn't worth spending money to correct it. The gaps could be slightly tighter - maybe 1-2mm per side.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 03-28-2016, 11:46 AM
El Duderino
tirwin's Avatar
Mine is from MA Shaw also. My paint/body guy -- John Holt -- worked with Shaw. John had an old plain decklid and he mated the top portion of the Shaw fiberglass lid to the bottom steel frame of the original decklid. John did a little work on it to improve the fitment but not much.
I've had several compliments on it since I got it last year. I like it because it has more rigidity than just fiberglass.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 03-28-2016, 12:02 PM
Bill Verburg's Avatar
On my '72 I tried 4 different aftermarket 'Ducks' none fit as well as I would have liked.
I think that one built on an oe steel or al.deck would be the way to go, these weren't generally available back in those days, but it seems to me that I have seen such, though I'm not really in the market.
Bill Verburg
Old 03-28-2016, 02:35 PM
Counterclockwise?
I understand using the metal lids but it takes away from the weight savings.
Sadly, I know I need to return this ducktail.
It's a shame because I became fond of it as soon as I put in on.
Rod
1986 Carrera
2001 996TT
Old 03-28-2016, 02:56 PM
El Duderino
tirwin's Avatar
I have my original flat decklid hanging on the wall. I just picked it up for comparison and it is so much heavier than the ducktail. Yes, using the steel frame is still heavier than all fiberglass but not by much.
Old 03-28-2016, 04:15 PM
gliding_serpent's Avatar
Rod, you know how my getty tail went. Not perfect out of the box, but quite good by some people's standards. None are perfect i think, some are better thsn others, and i think a big factor is owner expectations and standards.
The top of mine sat proud like yours did under the rear window... Not so arched or lifted however. But mine had meat to shave off underneath and it worked out great. And i am super anal. Yours looks very thin and highly arched. You would be having someone re-glass that entire top to make it work.
Nothing is more expensive than cheap fiberglass. Return it, get getty or ma shaw (basically same company).
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 03-28-2016, 05:26 PM
carwash's Avatar
Years ago, a man told me an amazingly true expression...
The cheapest man spends the most money.
I have found, through my own awful trial and error, that this is so true. I used to always search for the best deal, the cheapest part, the discounted buy, the buddy deal, the friend of a friend price, etc...
What then happens if I have to spend money to fix that part, or make it fit, or repair it, or need another part that wasn't included with it that I thought was, or I break the part trying to make it work, and then have to buy another one, or god forbid, buy the more expensive and proper part that I should have in the first place.
I'm not saying you're a cheap ass. I don't know what you paid for this part, but I hope it wasn't a ton, and I hope you can return it. Sometimes you get what you pay for, and I found this to be totally true when it comes to aftermarket Porsche parts.
This being said, I am waiting for my Ducktail to arrive from GT-Racing any day now. I will update here with the fit and finish of it. Good luck!
1968 912 - widebody - 3.2 - 915 - endless build
1980 911 - targa - barnfind nightmare - gone
1985 911 - targa - barnfind nightmare - gone
2017 991 - C4S - summer daily - for sale
IG - therealcarwash
Old 03-28-2016, 07:43 PM
