Current draw when engine off?
I drove three days ago in the day time. When I went to start the car this AM the battery was totally dead. The lights were not left on, the doors had been closed, everything electronic that I can see has been off. How can I test to see if something is pulling juice out of the battery when the car is off? And if there's a short, any ideas on how to find it?
82 911SC Targa
Old 03-30-2016, 01:09 PM
moneymanager's Avatar
Try a search. Lots of threads on all aspects this subject here.
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 03-30-2016, 01:22 PM
My friends call me Phish
Get a mulitmeter, and set it to amps
Unhook the positive battery cable to the battery.
Place the Black needle on the positive cable.
Place the Red needle on the positive terminal of the battery.
If a voltage appears that means that there is a draw.
Old 03-30-2016, 01:30 PM
Thanks! There was a draw and I found the culprit - the glove box light was on (yes, I feel foolish, but I couldn't see this very easily in the daylight). I must have bumped it getting my sunglasses out (Targa owner).
82 911SC Targa
Old 03-30-2016, 02:02 PM
Awesome!
Old 03-30-2016, 05:33 PM
Guardsred911's Avatar
After a few days with bad/ hard starting, I installed a battery cutoff switch. So my draw is zero!!
Old 03-30-2016, 09:50 PM
El Duderino
tirwin's Avatar
Glad you found the problem. Just to answer the question (I just went through this recently) I found on my SC that once I eliminated the parasitic draw the steady state use was 7-8 mA. Some people suggest anything higher than 30-50mA is something to investigate. That's a good rule of thumb.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 03-31-2016, 02:49 AM
T77911S's Avatar
Originally Posted by pemz0r View Post
Get a mulitmeter, and set it to 200.
that's not correct.
you have to measure AMPS.
it takes very very little current for a meter to measure voltage.
a test light works too. the brighter it is, the more current
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-31-2016, 03:38 AM
you are correct. i meant amps not volts.
Old 03-31-2016, 06:45 PM
