andy s's Avatar
need part number... Please
So for some reason I've lost the small (think they are 5mm flange bolts) that hold the crank pulley onto the hub (964 motor)
I've looked in PET, but the versions I look at don't show a part number for the bolts...
anyone know?
Old 04-02-2016, 06:31 PM
steely's Avatar
is it 12A (m6x30 900 119 026 02) in this pic?
interesting - the pic didn't upload...
try using this as the url -> http://forums.pelicanparts.com/uploads25/Capture1459659696.jpg
2nd edit - looks like a temp problem with graphics uploading tonight.
anyway, try checking out the PN
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 04-02-2016, 10:00 PM
andy s's Avatar
Thanks Dan, but that is for the upper pulley by the fan, I think.
These are to bolt on the lower pulley to a Hub, which in turn bolts to the crank.
I'm not by my engine now, but they seem to be about an M6, maybe 10-12mm long and the bolt head has an integrated washer head. also, the threaded end is tapered
Old 04-03-2016, 03:13 AM
