Administrator
Building a better Black Beauty #3: Reinforcing the Chassis
These pictures aren't comprehensive, and some of the work was only partially done when I took them. But they show the new tub for my car getting the following:
Deleting both battery boxes for oil cooler air flow. Sealing up holes from old dealer-installed AC. New version of car will still have the 37-degree AC engineered by TRE. Reinforcements for front, through-the-body swaybars. Welded in mounts for full cage. Power-assist brake setup from post-77 models. Welded-in reinforcements for real coil-overs as well as reinforcement of rear crossmember. Here are pictures, in no particular order.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 Last edited by Jack Olsen; 12-13-2002 at 01:17 AM.. |
Administrator
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 Last edited by Jack Olsen; 12-12-2002 at 03:00 PM.. |
Looks like good work Jack. How are you finishing the interior, trunk, etc? Will you completely disassemble everything after the mods are done and spray the complete car, interior and exterior?
Tom '18 Carrera T R #368, S #692 North Carolina |
Non Compos Mentis
Impressive!
Excuse me while I wipe the drool off my keyboard. |
Very nice Jack!
Jack,
That is GREAT! thans for all the nice up close pic's of the transformation.. SUPER.. I love the rear tower supports.. you are not going to weld the rol bar in? .. is it better to bolt in ot weld in? just wondering.. Thanks again Jack, BTW I was wondering if you still had any of the wheels for sale? Eric Mckenna
Famous last words.. "Hold my beer and watch this...' " The reason the Irish are always fightin one another is that there are no other worthy opponents ". |
SWEEEEEEEEEEEEEET!
It's going to be awesome. |
I thought the early cars were already set up for this? Isn't yours a 1973? Or is it set up for them, but still needs reinforcement?
Jack,
On the rear engine compartment photo, the welding they did in the corners. Did they install a plate or just weld the seam? Any closeup photos. Thanks for the info. Tinker |
Administrator
This new tub is a 72, and came with a factory swaybar, which goes through the body. However, the factory provided a fairly small swaybar, designed for tires that were skinny, with compounds that couldn't hold a candle to even today's average street tires.
So, to prevent the three bolts from tearing loose under the stress of modern bars and tires, you can reinforce the area where the bar mounts, and then drill out the hole to allow for a bigger front bar. The stock hole will accommodate the 22mm bar I'm currently putting in, but we drilled it wider as a preemptive measure. Tinker, I think it's just a beefier weld, but I'll take a look tomorrow.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
I'm jealous! I'd love to take on a project like this, and have some ideas rolling around in my head,but I chose to restore a VW crew cab this winter. Maybe next year.
I also wanted to use a '72, because I like the external oil filler.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Gesh Kevin, you could have at least candy coated it a little
Looks really decent!
Now all you need is turbocharged engine....repeat after me: boost is good boost is good boost is good all that 3.6 crapola has less than old 930 engine produces stock Hmm...i wonder what difference tricked out turbo engine would do with that light weight Yeah baby yeah!
Thank you for your time, |
Another top notch project. What about painting her Silver?
at least it got recycled into a sassy and useful dumpster.
oh...you mean the parts are on the *inside*. Oh Venkman...I'm sorry. We've been going about this all wrong. This Mr. Stay-Puft is okay. He's a sailor, he's in New York. We get this guy laid, we won't have any trouble |
Buy them, sell them
I just blew Vanilla Coke out my nose! It's looking good, Jack. Are you getting new 17" Fuchs for the RSR bodywork?
1931 Oakland Eight Special Saloon 1985 BMW E28 525e (Euro 528e) 1989 911 Carrera Sport 3.2 G50 Cabriolet |
fantastic jack
Rich ![]() '86 coupe "there you are" |
Administrator
Looks like it's coming along. It looks like it won't be too long til you're back out on the track.
Tim 1973 911T 2005 VW GTI "Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer |
Looks good! A question: what's the "proper" way to mount harnesses with that type of rollbar? Will you add a crossbar or simply attach to the rear bulkhead and run the belts thru the seat openings?
Greg |
