Both my turn signal lights come on please help
Hello
I've just noticed on my 1971 that whenever I actuate the turn signal on any direction it blimps twice on the correct side and then starts to blimp on both sides just like the hazard lights.
The column switch is new and there seems to be nothing wrong with it, did I wire a ground wrong? Has this ever happened to anyone? Please help.
Thank you
MD
"With an stock-original car, you serve the car. With a hot-rodded car, the car serves you."
Old 04-06-2016, 09:17 AM
roodog911's Avatar
Look at the directional lights from outside the car ... I found that one bulb was out when I had the same problem.
"Circumstances may cause interruptions and delays, but never lose sight of your goal." Mario Andretti
'84 Targa
Old 04-07-2016, 02:18 PM
Senior Member
Jdub's Avatar
^+1
Often you can tap an indicator lens to get everything back to working. Next step is to take the lens off and manually move the bulbs to see what happens. Did you replace the stalk for any particular reason?
When I first bought my car part of baselining it was to replace all fuses and bulbs with OEM or equiv. from the same manufacturer/part run. Of course new bulbs in old sockets were a pain, and I learned to leave well enough alone when they would inexplicably go Lucas on me.
'78 Targa in Minerva Blue
Old 04-07-2016, 04:46 PM
#147 of 2096
I had something similar long time ago.
It was a one contact bulb in a two contact socket on the rear.
#147 of 2096
Old 04-07-2016, 05:39 PM
crunch527's Avatar
Usually this indicates an issue with one of the bulbs...domestic cars will do similar things when a bulb is out.
Old 04-07-2016, 05:53 PM
Send a message via Skype™ to Porboynz
Also check the earth to all the lamp housings, especially if the lamps are flashing at less than normal brightness.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 04-07-2016, 11:38 PM
Often it's the relay.
206 637 4071
Old 04-08-2016, 04:45 AM
