samourai71's Avatar
Installing a new rear deck lid shock.
Hi, regretting not changing it while the motor was out this winter.
How hard is it to change the 1 shock, it looks like the space to reach the back is a little tight?
Any advice.
Thank you in advance.
911 black coupe 1985 3.2
Old 04-08-2016, 12:37 PM
MindtrapX's Avatar
I'm doing mine right now.
Left was a bit rough to get to, but it wasn't too bad.
I am trying to remove the one on the right now.
Previous owner must have lost all the pins in the back, so he used an allen bolt with 2 nuts. Proving to be difficult to remove.
On the plus side, I have a K&N filter installed and once removed it gives pretty good access.
You shouldn't have too much trouble.
Good luck.
Kevin
'84 Carrera RoW Coupe
"I'd like to offer moral support, but I have questionable morals"
Old 04-08-2016, 01:01 PM
universeman's Avatar
Take a magnet and put it on the clip so you don't lose it - trust me that thing wants to fly off into your engine compartment and hide. That's key. Another way is to tie a string to it and let the other end of the string dangle to the floor (or tape it to the car)
Everything else is super easy, access is a little tight however. Lift/retract the lid once you have the clip off, this will help you get the bolt out.
Nice maintenance improvement, makes working on the engine a lot better
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 04-08-2016, 01:08 PM
Counterclockwise?
I`m pretty sure that`s stock because the 1st nut is welded to the bracket.
Rod
1986 Carrera
2001 996TT
Old 04-08-2016, 01:34 PM
MindtrapX's Avatar
This I did not know. That may be my issue. I soaked it with some PB Blaster last night. I'll have another look at it this evening.
Thanks for the heads up!
Kevin
Old 04-08-2016, 02:10 PM
Good, you got that done.
Now, time to change the left front hood shock and get the clip back on.
Bruce
Old 04-08-2016, 06:19 PM
sugarwood's Avatar
Put a pillow down and kneel. That helps.
I used a small 1/4" ratchet to loosen the retaining nuts/bolts.
I also spread a towel under the shocks, in case the bolt fell down.
1986 Bosch Icon Wipers coupe.
Old 04-08-2016, 07:17 PM
samourai71's Avatar
Thx guys for the tips, I only have a shock on the left side but I see the right side has a place for a second shock. Maybe an option?
Obviously I'm thinking of a heavy duty shock, especially if there's only going to be 1.
I will give it a go after ordering and receiving the shock.
And then the 2 front shocks will be next.
BTW Are the front and back shocks the same or different?
Old 04-09-2016, 12:33 AM
Consider going with a mechanical hood strut - works great and are extremely well made - check out 356racing.com website - no affiliation just glad I'm using these
Old 04-09-2016, 02:07 AM
911 enthusiast
tmadden2's Avatar
I've had good luck using a long hemostat for this job. They'll lock onto the clip and you can push and pull them to get them off.
Old 04-09-2016, 02:52 AM
sky1jord's Avatar
Front and back are definitely different.
Supporting the rear requires only the left side shock. My understanding is that a right side rear shock is only required if you're running a Turbo Tail (more weight to support).
Only purchase the Heavy Duty shocks, the standard ones don't last long (ask me how I know)
Tying some dental floss or similar to the clips can be useful when the clips are invariably dropped.
Haven't tried it, but the hemostat idea sounds great.
Old 04-09-2016, 09:36 AM
samourai71's Avatar
Makes sense (for the turbo tail).
Interesting options for the shocks, but I think I'll stick to a more original setting.
And I'll definitely go with some heavy duty ones.
I heard that (more in the rear) that the heat of the motor is one of the reason these shock don't have a long lifespan. Is that true?
Old 04-09-2016, 10:51 AM
Here's I did mine. Used a mechanic wire to hold the clip in place. Never loose any clips at all.
Old 04-09-2016, 04:58 PM
