Charles Freeborn's Avatar
Decel valve bypass
My Decel valve has likely died. When disconnecting one that's suspected of a diaphragm failure is in necessary to unhook and plug all hoses to and from, or just the smaller vac hose?
Thx.
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 04-20-2016, 11:35 AM
If just the diaphragm has broken, then I think you only need to plug the little hose that pulls on the diaphragm.
If you also have a leak on the valve portion itself, it's best to plug all three hoses.
They're pretty easy to test - Vacuum pump on the diaphragm side and see if it holds vac.
Old 04-20-2016, 07:51 PM
Thanks Jim! Should have asked you on Saturday.... Installing MSD now, then on to valve adj and decel bypass. Might make it to c 'n c if not too busy before track day on Sunday.
-C
1972 914/4 Race Car
Old 04-21-2016, 06:52 AM
Cool - Would like to hear what kind of improvement you feel with the MSD.
Old 04-21-2016, 08:36 PM
