Is the muffler m+k also?
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
Aren't you using one of Sal's chips? If so, it would be great to see a comparison.
So you were going to order Sal's chip as expressed in this thread: Engine Volume Air Flow 3.2L Quote:
Dave Last edited by mysocal911; 04-20-2016 at 08:46 PM.. |
Peaks or dips that deviate from the optimum targeted AFR of around 13.0-13.2 is just part of the inherent variation that exists between engine to engine caused by such things such as cam timing, valve lash, manufacturing tolerances, wear on the air flow meter, type of air filter used, the make of premuffler and or muffler used, the fuel and percentage of ethanol, sensor variations, etc..... Also at the peak torque region of a motor, where the VE is greatest, usually you tune less ignition timing and/or also go slightly richer to prevent predetonation. The greatest variations on a 3.2 occur after 4500 rpm usually, and just like a rack suit vs a custom made to fit, so if you want to perfect it, you can use the dyno AFR data to reprogram a custom tuned chip specific to the motor. Although in the above example, it's really not necessary and any such tweaking would result in minimal gain
Fastest Hunk of Junk
I'll pile on, too
![]() Steve Wong chip made the biggest difference to my idle. The stock chip had the idle hunting a bit, and it would die too easily right after start-up. I was also pleased to find my CA wires connected, so a free ~7hp there! Overall the car is much pokier and more enjoyable to run to redline. I need to race my M5 again to see if the 911 can now beat it with the SW chip
-Brent |
The SW chip sounds great and I had planned on this upgrade before I get my project back on the road this summer. However, I've also been reading about Sal's chip (and new injectors, etc.). I wonder if there are any comparisons out there to know which approach provides the best driver satisfaction. How did you guys decide on the SW chip? I've read lots of good things so did most of you simply expect this is the best option or was there other things you reviewed and then decided against?
84 911 Targa Carrera currently getting renewed |
Brap
Well there's pros and cons to each. Both serve as a way to tune the car, but they really serve different markets.
SW Chips: Plug and play, easily reversible, use your existing AFM/injectors, custom tunes available, relatively inexpensive if you just want to tune your car, you can order it off a website. Sal System: Totally new MAF/injectors, totally custom, requires WBO2, lots of time on the phone with Sal, more expensive, burn your own chips, etc. I'm a huge nerd, so I went with Sal and I'm glad I did. I want to get my hands dirty and learn more about this car. I already have. I'm still in the process of getting my car ready to accept his kit. But I'm enjoying the process more than I would have if I'd just chipped the car, and that's really what I'm excited about.
1980 911SC Coupe 3.4 1995 Miata 2005 Tacoma 2009 Street Triple |
without the added cost of a new MAF/injectors, nor needing a WBO2.
Dave |
I've had a SW chip in my car for about a month now and 'am more then happy. It's a "lightened" 88 3.2 with Fabspeed pre-muffler, M&K 1-in 2-out, went with the 93 octane sport muffler chip. The car definitely had lost some mid with the 2-out exhaust but the chip brought it back to life. The biggest positives I can clearly feel is more low-mid range usability, meaning for example I can now cruise roads in 4th at 3000-3500 rpm and the car now responds very well, feels like what 4500 in 4th used to. The power delivery through the whole range is smoother for lack of a better word and the power feels like it keeps going to redline without falling off. For those thinking it's going to turn your car in to a Turbo, it's not. Best description is it refines the whole rpm range giving you smooth or smoother responsive power where you did and didn't have it before before. Idle has gotten more consistent and letting off the gas in the power band results in a "purring" type decelerating idle that wasn't there before. Looking forward to seeing what it does on the track in those screaming rpm short 3rd gear straights before a corner that there is no time to go to 4th.
______________ '88 911 Coupe '98 Spec Boxster '85 380SL Benz -Euro |
Brap
You're right Dave, I stand corrected.
Is there comparison data (dyno) for Steve Wong vs Sal's tuned setup?
Jay B. 85' 911 - Black 69' 911 - Signal Orange |
My knowledge comes from turbo motors, where high RPM + lean AFR is a recipe for internal failure. Is this a function of an NA motor being more receptive of such a condition? Or an inability by the ECU to control the AFR with such fidelity? |
The air flow meter door basically maxes out at around 5200 rpm so its ability to measure further air flow increases stops. Thereafter the quantity of fuel is dictated by what is preprogrammed in the fuel tables which is addressed either through a chip program already developed to match a particular engine/exhaust configuration, or with custom programming. It is not a problem, as the 3.2 and it's injection system has the ability to supply enough fuel for engine displacement increases of 3.5L and beyond. Different engines hit this max point at 5000-5200 differently so thus the greatest variations occur after 4500 rpm.
With regards to the dyno chart you refer to, as I mentioned, the target AFR at full throttle for a Porsche engine for max power is 13.2 to 13.0. That engine is not leaning out after 5000, but went slightly rich to what looks like about 12.6 at 5000, and going back up towards the target ideal of 13.0-13.2. So there's nothing to be concerned about. Generally on a n/a motor, full throttle AFR variations between 12.5 and 13.4 have very little influence on overall power output and reliability as that is the top of the bell curve. Maybe 2-3 hp at the most. If an owner want's it tweaked to perfection, then fine tuning the chip from dyno AFR data is an available as a custom option. |
Steve,
Can other providers of AFM's like VEMS or others plug and play with existing Motronic or do you need their specific ECU too for it all to work right
1980 911 - Metzger 3.6L 2016 Cayman S |
Still here
Brew Master
As to Dyno charts. I hope to be taking my car to a dyno and will try to post results in my thread. |
Just a question about people using a SW chip to correct idle problems. Is this just masking the real issue? The 911 obviously did not have idle issues when new. So, is the SW chip just a band aid for whatever is causing the idle issue?
1986 Bosch Icon Wipers coupe. |
Another dumb question. In other cars, people replace the AFM/MAF all the time. Why does this seem like a very rare thing on a 911? I bet the majority of us are using the original AFM. In fact, you can barely even buy a replacement AFM if you wanted one. Is it a different design than modern MAFs that get replaced all the time?
Brew Master
I would guess if you told Steve you were having idle issues he'd suggest looking into that before installing a chip. But I'd say you are absolutely masking a problem. I know my car idle searched and it wasn't until I went through everything including setting base idle mixture that things cleared up. Once I had things working the way they should I had a chip put in my car.
I have a steve wong stage 2 chip that i bought for my car before i realised i needed a rebuild. It was for ssi's (which i had) and was off the shelf stage 1 before i paid to have it upgraded to stage 2. I never did get it dyno tuned as i had my car back on road at the very end of the season last year after an extensive rebuild. My car was running well, but quite rich (i have a wideband). Like up to 10:1 on wot. Not to get into details, but SW gave me some advice. I am back at trying to figure it out. Now, a PO had fiddled with my afm. I fiddled with it a bit also, and improved things a bit, but over the winter, I kind of took a left turn and got Sal's maf/chip/injector setup. I had no issues with sw's product, and again, have not yet had him dyno tune it in so I cant say much. I first need to confirm my engine is 100%. I dont want sw to be tuning around an issue that we both dont know about. I will get the sw chip dynoed and tuned-in this year because i am keeping my stock injectors and afm, and I doubt he would appreceate me calling him up 10 years post purchase to have him dyno tune his chip. I got mine in the fall of 2014. So i can compare sw/afm to sal/maf. I am going to compare a stock 89 chip/afm to sals chip/injectors/afm to sals full maf setup. All dynojet, all same day. I will post a thread on it. However, i will not be doing/sharing the sw vs sal dynos. They are both outstanding members of our community, and both have treated me well. I know sw does not piss in people's cerial, and nor does sal. Nor do I. I have no intention of steering this thread off topic. Steve wong 100% knows his stuff and you can't go wrong with him. And he gave me a lot of good advice. I follow his facebook page and he gets impressive numbers from his tunes that never fail to surprise me. He also has a mind for safety and reliability which is key. I fully believe in supporting good people in our little hobby. I just went in another direction for different reasons. Partly because i geek out on tech, and had injectors and an afm of questionable tune. When i thought about replacing/refurbing them, the cost/benefit analysis changed a bit. Sal is a great guy too, just like steve. Two very good folks.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS Last edited by gliding_serpent; 04-23-2016 at 09:34 AM.. |
understood that tweaking the AFRs was critical to achieving peak performance for a fully stock 3.2 911 engine, e.g. stock exhaust/CRs. If it's not the tweaking of AFRs that help improve performance, how then can chip tuning increase performance even at middle range?
Dave Last edited by mysocal911; 04-23-2016 at 10:03 PM.. |
