How could fuel lines be run down the tunnel?
In my '75 hot rod someone ran the lines (feed and return) down the tunnel......inside the boxed reinforcements in the top corners of the tunnel (one line on each side, inside the box). Is that normal? I want/need to weld on that area (yes I saw recent posts about that). I am wondering if moving them down to just lay in the tunnel is better??
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
On my '74, both feed and return are run down the driver side thru a "tunnel within the tunnel".
Yeah, both should be on top side of drivers tunnel.
1997 BMW M3 (race car) with S54 engine swap "The Rocket" 1984 Porsche 911 3.4 Carrera 1973 BMW 2002Tii 2016 Ford Focus RS |
