Kind of Blue
Why didn't I order a Steve Wong chip sooner?
Wow, what a difference in the mid-range of the power band. My car had an obnoxious hesitation right around 3000 RPMs that made it annoying in any normal driving. I replaced the plugs, air filter, fuel filter, distributor cap, wires, and it still persisted.
Well I put the SW chip in Friday and it was immediately gone. The car is so much more enjoyable to drive on the streets as the powerband is far less peaky and far more usable from 2500 - 4000 RPMs. Overall, the swap took about 30 minutes, the hardest part being bolting the Motronic back down underneath the seat due to the awkward access.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Cool. I have a Steve Wong chip installed for my '87 3.2 motor with 964 cams. I can't wait to drive it and see how it runs.
'71 914-6 #0372 '17 Macan GTS |
Kind of Blue
I'd love to see what a difference 964 cams make as well.
SW chip + M&K premuffler / 1-in, 1-out muffler = 211 RWHP (dynojet dyno recently), which is a big increase over stock. Silky smooth torque and hp curves.
Kind of Blue
I have a Monty muffler but a stock cat. I considered a premuffler but didn't want to fool with it with our emissions inspections.
Still here
Nice!! I've had my eye on an SW chip for a while. Which one did you get, the stock or the pre-muffler one?
Also, and I don't mean to thread drift too much here, this hesitation around 3000, was it persistent or more of a random thing? I ask because my '89 3.2 does something similar, but not on any frequency I can determine. Just sometimes while driving (and it normally happens when cruising for a while) it will start to act like it's missing or hesitating in the 3000-4000 range, and not everytime I drive it. The only consistency is that it happens around the same RPM range, but other than that, I have not been able to figure out a cause (not that I've really looked to deep into yet, getting other issues squared away first). |
Kind of Blue
Yes, this sounds exactly like the issue I was having. It wasn't every time, but occasionally right around 3000 RPMs and it felt like there was a pause with the throttle but with no associated noise indicating something wrong.
I just did 91 octance premuff chip, MK premuffler, and 1 in 1 out MK -- brilliant. same as OP -- can't believe I didn't sooner and as jeff bottman has said to me in the past -- I'm now a bit of an evangelist for this set up. lighter faster and relatively cheap -- what's not to like
Still here
http://www.911chips.com/dyno.html Last edited by pmax; 04-18-2016 at 03:31 PM.. |
OCPO
Typically there is no emissions on 30 year old cars but your state maybe different. Have the SW chip /MK pre muffler with stock exhaust. So nice.
2018 X5 86 911 Targa 3.2 80 Mercedes 450SL 2006 530xi BillyBoat/H&R's....gone Last edited by Storage Man; 04-18-2016 at 01:13 PM.. |
I find it's easier to remove the drivers seat to get to the brain box.
87 911 street/track/Sunday car Not for the purest. |
Thanks for the reply. I guess that gives me another reason to get the SW chip, not that I think it'll for sure stop the missing, but with the other gains and possibility of helping out there, there's no reason to not upgrade.
- Chris |
OK, I'm a shameless promoter of Steve Wong chips and M&K products. Here's the Dynojet dyno curves for stock '86 targa, Wong chip, M&K premuffler and 1-in 1-out muffler:
Good to hear another positive response on the chip swap,
did mine a few years ago, and wouldnt go back to the standard chip now.Steve's a good guy to deal with too. ![]() A.
"But instinct is something which transcends Knowledge We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile" Nikola Tesla Last edited by ant7; 04-19-2016 at 02:46 AM.. |
Burnin' Rubber
One of the best mods I've done for my car a few years back. Immediately noticeable difference.
I did a bursch cat bypass and one in one out exhaust on my 87 911 3.2. I also did the Steve Wong chip this week. Wow, what a difference.....it pulls so much harder in the lower RPM range and the idle is smooth as glass. I had to adjust my idle down 200 RPMs after the chip and I made sure to disconnect the brown wire for emissions ( I guess I have a California spec 911?) I still need to check and make sure I'm getting 100% throttle open when pedal is pressed, but I did a minor adjustment already. Money well spent! I got the 91 octane chip for my setup in case I go out west with it.
I will also say they mailed it the same day I ordered it and it was sent priority mail to my house in about 3 days and I live in Georgia. Great customer service. It came with all the instructions and I feel they went above and beyond when it came to everything.
