-   -   How many here have experienced DME relay failure? (http://forums.pelicanparts.com/porsche-911-technical-forum/912411-how-many-here-have-experienced-dme-relay-failure.html)
widgeon13 04-30-2016 06:07 AM
Did it occur while driving or at start up.
Is this the most common cause of start up failure in your opinion?
trader220 04-30-2016 06:22 AM
Start up
Eric Hahl 04-30-2016 06:24 AM
Start up here as well.
ssupman 04-30-2016 08:06 AM
Dme
Start up.
JAR0023 04-30-2016 08:21 AM
Startup.
NSJ-911 04-30-2016 08:48 AM
Ditto.
Arne2 04-30-2016 08:49 AM
Start up for me as well.
wwest 04-30-2016 09:53 AM
Intermittent until it wasn't..
patz 04-30-2016 10:23 AM
Both. While driving it ended by being a bad/worn fuse on the end from spinning to free up corrosion since I am near the ocean.
I got rid of the problem by going to the updated fuse box using bladed fuses.
cabmandone 04-30-2016 10:25 AM
Dead on startup.
DeRRis 04-30-2016 11:23 AM
When my car was delivered it would not start. Even though the PO had driven the car onto into the transport trailer. It was de DME relay.
Dooodahman 04-30-2016 01:58 PM
Driving. Turned off when stopped at a stop sign.
300cd300sdl911 04-30-2016 02:35 PM
Just last week - start up 1985 911 euro. Changed DME fired right up!
jeffbottman 04-30-2016 02:42 PM
How hard is it to change? Can it be done at the roadside, and where is it? Sounds like I should be carrying one!
Techno Duck 04-30-2016 07:20 PM
Pretty simple, its under the drivers seat next to the DME. If you have 4-way power you can lift the height of the seat up all the way to get more room for easier access. Reach from behind and pull the plug off. Then from the front you can remove a 10mm nut that holds the relay down to the floor.
rokemester 04-30-2016 07:26 PM
just picked one up from our host and it's in my glove compartment. I feel better;)
Canada Kev 04-30-2016 07:37 PM
Put it in your car and try it out. It'd kinda suck to need one sometime and find that your shiny new one you got as a spare is DOA. Doesn't happen a lot, but it does happen...
rokemester 04-30-2016 07:44 PM
Good point...that's why I love this forum.
sky1jord 05-01-2016 08:14 AM
Startup 12 yrs ago. Had no idea what the problem was, so I had it towed to a dealer to get ripped off there. I now carry a spare.
11and14 05-01-2016 09:42 AM
Start up, also carry a spare...
