JOHN21BLACK's Avatar
Best starter for 911
Planning to buy a new starer for my 911 any suggestions?
Old 09-20-2015, 10:16 PM
gshiwota's Avatar
I've used both the orignal Bosch and the newer "high torque" started from our host. Both work great! The high torque starter definately is stronger and "works better" in my opinion. However it doesn't sound right to me. It sounds like a newer japanese car / motorcycle to me when it's turning over. Nothing wrong with that however with my Porsche-OCD, I prefer the lazy sound of the OEM Bosch starter.
Old 09-20-2015, 11:39 PM
a.k.a. G-man
Geronimo '74's Avatar
I bought one from a forum member.
Lightweight (2.7 Kg !!) and high torque.
Huge weightsaving compared to the stock starter.
Never lookted back.
Old 09-21-2015, 01:38 AM
High torque starter for sure. Saves weight where it counts. Yes, it sounds different. Who cares what the starter sounds like? Oh wait, it's not concours.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 09-21-2015, 05:00 AM
The sound is "funny" but the high torque lightweight starter is the choice I went for.
I do drive mine on road trips. The Bosch starters tend to get hot and heat soak and then lock up until they cool off some. Mine only did it on road trips. It never did it in normal around town driving or on short trips.
The smaller high torque has been flawless. I have two of the huge Bosch starters in my attic. I guess I need to put them up for sale and get rid of them. I will not be using them.
Old 09-21-2015, 06:40 AM
I replaced my starter last year. I went with the "hi-torque"starter.
Works great.... still have not got used to the sound !
Old 09-21-2015, 06:46 AM
Diss Member
Quicksilver's Avatar
Put in a hi-torq starter 15 years ago. Haven't looked at it since.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 09-21-2015, 07:55 AM
Spiderman
Jesse16's Avatar
old vs new
My take is they both work when new, I went hi-torque for the lower cost and easier install because its physically smaller vs. new but probably not built in Germany as my old one was from Bosch. This was after having the Bosch rebuilt once locally and it failed again after a year. (not such a great rebuild obviously, least it was inexpensive). Its just a starter.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 09-21-2015, 08:09 AM
If you're stuck somewhere or you're on a budget, just use a VW auto-stick starter. IIRC it has the same torq as a regular 911 starter and it doesn't come with the Porsche price surcharge.
Also, they were Bosch supplied with the same part number as used on the 911. Again, the autostick only, NOT the 4speed ACVW . It will work on all 911's up to 1989.
Just FYI
Old 09-21-2015, 08:13 AM
tobluforu's Avatar
I swear, and maybe I'm wrong, but it sure feels like the hi torque spins the motor quicker which makes my old 72 catch faster.
Old 09-21-2015, 08:19 AM
I was wondering if that really is another benefit to installing a HT starter. Do they in fact make your engine crank faster for quicker starts?
1970 914-6 #2615 (Metallic Green) - SOLD
1974 911 US Carrera Coupe #63 (Lime Green)
1973 911 T Coupe #1891 (Gemini Blue)
Old 05-07-2016, 03:54 PM
Chain fence eating turbo
High torque starters are really a no-brainer. Lighter, far more compact, and sound really cool and racey
Old 05-07-2016, 04:08 PM
Still here
pmax's Avatar
Weight and possibly reliability wise, the HT wins.
Personally, I will always stick to the OEM starter. HT starters will fire the engine up quite a bit faster than the Bosch. Given oil pressure takes time to build up, I don't mind a slower starting crank.
Just my 2c !
Old 05-07-2016, 06:28 PM
Reiver
Reiver's Avatar
Just my 2c !
RPM is rpm....they build pressure at the same rate related to the rpm. Slower spinning builds pressure slower so there is no 'savings' in that regard.
The weight and size. You have a lot more room to below with the smaller lighter units.
De Oppresso Liber
Strength and Honor 5th Legion
Old 05-07-2016, 07:07 PM
Cars Ruined My Life
impactbumper's Avatar
Damn it i just replaced mine with oem bosch and did not remember the ht starter!
Old 05-07-2016, 08:25 PM
Wer bremst verliert
JohnJL's Avatar
The hi-torque starters I have used I have logged with lower cranking speeds than the stock ones. I still used the hi-torque ones and have never had a problem after many years, but you may need to compensate for cranking speeds. For example, one EFI ecu I know of wont recognize the car as cranking at ~250 rpm that the hi-torque versions. You need to go in and edit the cranking thresholds.
I havent heard of this being n issue on stock cars, but maybe informative for those commenting on teh different sound (it is slower than a healthy OEM unit) and for anyone using an aftermarket efi.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 05-07-2016, 10:04 PM
Pretty sure high-torque starters spin the same or slower than OEM.
Old 05-07-2016, 10:31 PM
Formerly known as Syzygy
Canada Kev's Avatar
Which makes sense. To be able to use the smaller, lighter starter motor, but still creating the high torque, they're geared to gain a mechanical advantage. Thus a higher rpm light weight motor, geared down to make good torque equals similar or perhaps slower speed at the ring gear.
Kevin
Old 05-08-2016, 07:18 AM
Wer bremst verliert
JohnJL's Avatar
This is what I have logged in a couple cars with both.
Old 05-08-2016, 09:40 AM
Still here
pmax's Avatar
This video seems to show a HT starter firing the car up a
lot quicker. The OEM starting crank takes almost a sec before the
engine rumbles to life which is about what my 87 does.
https://www.youtube.com/watch?v=k1yYxhpbD2A
Old 05-08-2016, 11:07 AM
