Window motor wiring
Having difficulty finding where the window motor wires connect on the motor. I've got access to the motor and regulator, but I can't see well enough inside the door compartment to see where or how they connect. Any directions or especially pictures would be greatly appreciated. 1986 911 targa. Thanks
83 911SC Cab
hoping this helps....
So the two yellow connectors are where the two wires connect from the switch to the motor? Sorry I'm new to this procedure. Thanks for the pictures. I'm assuming I remove the two wires at that connection and then I can remove the window motor and regulator??
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Motor.
Are trying to remove the motor?
Or, just the wires? You can remove the motor without removing the regulator. pm me as needed. Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 05-03-2016 at 10:43 AM.. |
I tried to send you a pm. Guess I don't know what I'm doing there also. Haha. Yes I'm just trying to replace my window motor only. I thought the regulator comes out along with the motor?????? Thanks for your replies
Also, I was lucky enough to have a switch-to-motor cable that had a 2-terminal connector to mate at the motor end, making it much easier to make a connection than dealing with two independent faston tabs. Good Luck |
This should give you further help.
Porsche 911 Window Regulator and Motor Replacement | 911 (1965-89) - 930 Turbo (1975-89) | Pelican Parts DIY Maintenance Article |
Thanks to Gerry and sky for there advice. I finally got the motor out without removing the regulator. Mine also has a a two cable connector. Can either of you please tell me where I can/should purchase a new motor. Was thinking about a used replacement, but don't want to trust the condition and I'm also not too eager to do this job again anytime soon. Any feedback is always appreciated. Thanks again. Gary
